Author: Subject: Moulded Foam Seat
deeceee09
posted on 19/1/13 at 09:22 PM Reply With Quote
Moulded Foam Seat
Has anyone made a two part PU moulded foam seat then covered it with a layer of GRP and finished it off with topcoat? If so what results did you achieve? I have covered a previous seat with duct tape but am looking for a better finish without going to the bother of producing a buck, then a mould and finally a moulding.
Treachery and old age will always triumph over youthful enthusiasm.
T66
posted on 19/1/13 at 09:26 PM Reply With Quote
by coincidence, I watched this about ten minutes ago...Cafe racer seat unit
http://www.youtube.com/watch?v=AT6P7qaUPLw
http://www.youtube.com/watch?v=klcwT2IMznU
maccmike
posted on 19/1/13 at 11:18 PM Reply With Quote
be interested to see the cafe racer end result
deeceee09
posted on 20/1/13 at 11:42 AM Reply With Quote
Thanks for the links. I wonder what type of tape he used?
posted on 20/1/13 at 11:55 AM Reply With Quote
I can see Mighty-Mouse being ditched in favour of a cafe racer project! You're spending an unhealthy amount of time ogling classic bike porn Ivo!
It's Evolution Baby!
T66
posted on 20/1/13 at 12:28 PM Reply With Quote
Definitely not, when the Moose is finished, I have just enough room for a Harley/Moto Guzzi alongside it..
I've realised to swoon after Unimogs & Zils isn't realistic.
Slimy38
posted on 20/1/13 at 03:22 PM Reply With Quote
I've seen a similar process used to build a car;
http://www.youtube.com/watch?v=PNxZjOExd6g
They just used standard duct tape to keep the foam and the resin separate and act as a release agent.
[Edited on 20/1/13 by Slimy38]
T66
posted on 20/1/13 at 03:58 PM Reply With Quote
This one is duct tape, wiped down with car wax before he starts layering it up..
Splits easy enough.
RK
posted on 21/1/13 at 12:02 AM Reply With Quote
Is there any reason one can't use any old car seat cover (that you can buy for next to nothing), trimmed down a bit, and resewn? Nobody talks about this, but what are the fancy bead ones you see using? Special fire proof material, trimmed and upholstered, and that appears to be it.
Very cool cafe racer seat vid!! I wonder where he got the blocks?
[Edited on 21/1/13 by RK]
loony
posted on 21/1/13 at 07:44 AM Reply With Quote
E-bay ? 2 Oasis WET Foam Brick Floristry Blocks
[Edited on 21/1/13 by loony]
Lucas
Slimy38
posted on 21/1/13 at 08:10 AM Reply With Quote
E-bay ? 2 Oasis Wet Foam Brick Floristry Blocks Fresh Flowers
Are those the actual blocks though? I got the impression from the video that between the dozen or so blocks he used, and the spray adhesive to glue them together, the tin of glue was more expensive. If he'd used those foam bricks, it would have been the other way round.
Unless they can be got much cheaper?
loony
posted on 21/1/13 at 08:23 AM Reply With Quote
You can buy them cheaper:
2 X OASIS FLORAL WET FOAM BRICKS / BLOCKS, MAXLIFE, FRESH FLOWERS.
or box of 20 for 11,30:
Florist Wet Foam Blocks / Brick - Box of 20 (Value alternative to Oasis brand)
Lucas
Slimy38
posted on 21/1/13 at 09:26 AM Reply With Quote
Aha, that's more like it, thanks.
