ali f27
posted on 22/2/13 at 01:09 PM |
which lambda
Hi going to weld in a plug for lambda sensor so can map dta anybody know which lambda to buy and where from locost style
Cheers Ali
Craigorypeck
posted on 22/2/13 at 01:49 PM |
the AEM wideband is a self contained within the dial unit thats nice and easy to install with minimal fuss.. and I think it has a 0-5v output that can
be used for data logging.. the innovate system has a control box that need to mounted near to the sensor (well within about 2' and needs a lot
more wiring, its setup for data logging too.
both are expensive at around 150 so there may be better low cost options out there.
Slimy38
posted on 22/2/13 at 01:57 PM |
I've had this sat in my Ebay saved searches ever since someone else asked the question;
AEM Wideband AFR Lambda UEGO Gauge - Complete kit | eBay
It's the AEM that Craigorypeck talks about. I get the impression that despite it's anti-locost price tag it's very effective.
beaver34
posted on 22/2/13 at 01:58 PM |
i use the AEM its great and has that 5v out for dash or data logging which i also use
rdodger
posted on 22/2/13 at 03:46 PM |
Innovate MTX-L is what I use.
It comes with a nice clear gauge and has outputs for ecu etc. Very easy to wite up and calibrate. The controller is built.
http://www.innovatemotorsports.com/products/MTXL.php
The LC-1 is standard unit and works the same but as standard has no gauge. You can output to a digidash and ecu etc.
