Author: Subject: steel tube
matty h
posted on 22/2/13 at 08:00 PM Reply With Quote
steel tube
I am on the look out for some steel tube preffer stainless steel.
Inside diameter of 12mm / 1/2 inch and around 19mm outside diameter.Need around 400mm.
Anyone know where I can get some of this from.
Thanks Matty
Talon Motorsport
posted on 22/2/13 at 09:04 PM Reply With Quote
Would this be for suspension crush tubes?
jossey
posted on 22/2/13 at 09:48 PM Reply With Quote
Give Metal4u a call in pontefract I have Togo to pick up my stuff so I can get yours too.
David Johnson
renetom
posted on 23/2/13 at 09:15 AM Reply With Quote
tube
We purchased a pair of rose jointed top wishbones from MK
But rather than have to get made up spacers (crushtubes)
we used stainless steel washers instead, needed 80 all told 20 per leg
This made it much easier to set up caster & assemble, as you can fit one washer
at a time until you have the caster right , then fill in the rest, easy peezy.
both sides of the car were different.
washers were about £5 for 100.
Good luck
Stainless washers as crush tubes
matty h
posted on 23/2/13 at 06:56 PM Reply With Quote
They are indead for suspension crush tubes, striker top rocker arm.
Will give metal 4u a call on Monday see if they can help.
Thanks Matty
loggyboy
posted on 23/2/13 at 07:37 PM Reply With Quote
Try Raw?
Mistral Motorsport
