Author: Subject: Alternator grooved pulley
wombat
posted on 20/5/13 at 04:15 PM Reply With Quote
As title, anyone got one kicking about before I go to the scrappy?
Can get bits machined to suit if needed.
tims31
posted on 20/5/13 at 07:48 PM Reply With Quote
Hey Wombat,
Yep I think I have one still attached to the alternator I removed from my Zetec, I will double check and let you know. Over in Wisbech at the start of next month too if you can wait?
Build: http://www.martinsfurybuild.co.uk/
tims31
posted on 20/5/13 at 08:13 PM Reply With Quote
Yep I have two, one from a CVH Sierra and one from the Zetec 78mm od and 48mm od.
alternator-pulley
alternator-pulley
[Edited on 20/5/13 by tims31]
wombat
posted on 20/5/13 at 08:49 PM Reply With Quote
Great, any idea which size I need for silvertop 1998?
Ex karter too, 250 National back in the day....
tims31
posted on 20/5/13 at 09:03 PM Reply With Quote
ha, I did 100 national, Rotax Max and 125 Gearbox in my time. Was also a MSA instructor too teaching and licensing people.
Not sure which pulley you need but think it depends on what alternator you fit but sure you can change the belt to suit.
the smaller one would probably be the better one as that's what I have on mine but mines a Blacktop.
wombat
posted on 20/5/13 at 09:27 PM Reply With Quote
Searches seem to agree 48mm is the one, unless someone pipes up........
Have a mate who works in Spalding that could pick it up.....
big_wasa
posted on 20/5/13 at 09:36 PM Reply With Quote
What alternator is it going on ?
Ford stuff is a 17mm shaft and the smaller denso alternators are a 15mm shaft but a bush is easy to make or buy.
tims31
posted on 21/5/13 at 06:25 AM Reply With Quote
I'll remove the 48mm od one from the alternator and measure the id so you know.
If your mate was to pick it up it would have to be in the evening or sometime over the weekend.
tims31
posted on 21/5/13 at 08:42 PM Reply With Quote
Have removed the pulley and is 17mm id.
Let me know if you still want it?
wombat
posted on 22/5/13 at 08:06 AM Reply With Quote
Good job we all see this as fun !
Alt is an LRA100 ( I am led to believe - no sticker) and last night I found on the net that the smaller pulleys were found to over stress this model, apparently Tiger now supply a 68mm pulley to overcome this (Paul Toyne site).
So I guess I would be better off with the 78mm jobby you have...
Will need to check shaft size tonight, but can get a collar machined anyway with no probs
Thx for the input Warren, and......
On another note, my Trigger Wheel should arrive today, I intend to have a small recess machined on the crank pulley to keep it central, then drill and tap it to fix.
So........... eventually my question, how do I determine the position of the Trigger Wheel on the crank pulley?
big_wasa
posted on 22/5/13 at 08:16 AM Reply With Quote
The lra will be a 17mm shaft.
Trigger wheel, what flywheel are you using ? sounds like your making things hard for your self. You can stick the wheel on in any place as long as you can make a bracket to get the vr sensor in the position it needs to be.
wombat
posted on 22/5/13 at 08:22 AM Reply With Quote
Warren,
Its ok, I have changed the flywheel to the 1.8 so original sensor not used.
Yes, will need to make a bracket, but I have a plan :-)
Thx for that, just wasnt sure if I needed to mount the TW in relation to the keyway or anything, just double checking really, measure twice drill once and all that !
Tims31
Will probably nip over at weekend if I can get chance, will be in touch.
W
big_wasa
posted on 22/5/13 at 08:30 AM Reply With Quote
Confused,
The 1.8 zetec flywheel will work fine with the vr sensor and you wont have to think about the timing being out. As its mounted in the flange of the block its ridged and will not move or flex. ???
Or have you used the 1.8 cvh flywheel ?
wombat
posted on 22/5/13 at 09:06 AM Reply With Quote
B****r, then i have bought a TW that I dont need !
Oh well at least I dont have to buy another sensor, make a bracket or run wiring......
Thx buddy.
Its a learning process.......
Anyone need a brand new Trigger Wheel ??
big_wasa
posted on 22/5/13 at 06:34 PM Reply With Quote
Black or silver 2.0 fly's are the same as are 1.6~1.8. They are a different clutch size ie 220mm and 240mm but the dia of all the fly's are the same.
as long as yours has the holes on the back you don't need a trigger wheel and you wont get the same accuracy or reliability either.
side by side as they just happen to be on the bench.
wombat
posted on 22/5/13 at 06:46 PM Reply With Quote
Thx I will have to whip the starter off to check.
big_wasa
posted on 22/5/13 at 07:06 PM Reply With Quote
Only other thing you need to know is if the engine came from an auto or manual. The cps housing is different.
[Edited on 22/5/13 by big_wasa]
