iiyama
posted on 23/8/13 at 07:31 AM |
Hayabusa oil temps
What sort of temp should I be looking at for a dry sump set up? Temp sender is located at the oil filter.
If its broke, fix it. If it aint broke, take it apart and find out how it works!
ashg
posted on 23/8/13 at 10:38 AM |
it depends on the oil you are using. a good fully synth oil will be fine up to about 125degC, semi synth about 110degC. cruising around somewhere
between 90-100deg wouldn't worry me, expect you will see over 100 on a good thrashing. if your that worried fit an oil cooler.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
iiyama
posted on 23/8/13 at 07:12 PM |
Had a cooler, in fact had two! First one way to big, second smaller but still not seeing temps above 80. Have removed it completely now and saw temps
last night up to 100-102 with semi synth. Was under the impression that fully synth is not the best thing to use.
