corrado vr6
posted on 28/10/13 at 08:41 PM |
IVA tomorrow, what should I take?
Evening all,
I've got my IVA test tomorrow and just thought for peice of mind that I have everything ready to go for the morning
So far I have
- letter of appointment for IVA test
- all original receipts
- original photos of build
- insurance certificate (for plod)
- socket set
- pliers and spanners
- spare bits of trim
- knife
- duck tape
- electrical tape
- full tank of fuel plus 2 jerry cans
- spare water for coolant just incase
Can anyone think of anything else worth taking?
Thanks in advance and wish me luck
Greg
http://r1indy7.wordpress.com/
carpmart
posted on 28/10/13 at 08:46 PM |
rabbits foot?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
carpmart
posted on 28/10/13 at 08:48 PM |
number for recovery service in case you have a bad fail and they don't let you drive home?
A glass half empty comment, but better to be prepared......... ?
'94 MX5 MK1, 1.8
corrado vr6
posted on 28/10/13 at 08:51 PM |
Well I have break down cover which covers any car I'm driving through AA, not sure if it would cover the kit car though lol
Although luckily I do have a mate driving down in a van for moral support and to take tools etc down
jacko
posted on 28/10/13 at 08:58 PM |
Tie wraps
Good luck
Jacko
madteg
posted on 28/10/13 at 08:59 PM |
Tie wraps.
corrado vr6
Ah yes I forgot to list those, thankyou
Daddylonglegs
posted on 28/10/13 at 09:00 PM |
Paracetamol
steve m
posted on 28/10/13 at 09:01 PM |
Tow rope
AND more importantly
GOOD LUCK
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
gremlin1234
posted on 28/10/13 at 09:07 PM |
camara, (and an umbrella! )
[Edited on 28/10/13 by gremlin1234]
40inches
posted on 28/10/13 at 09:09 PM |
Double sided adhesive tape saved me having a fail.
Forgot to say best of luck, and enjoy it (yes, you can).
[Edited on 28-10-13 by 40inches]
Daddylonglegs
posted on 28/10/13 at 09:10 PM |
Speaking of cameras, don't forget to take a copy/piccy of your IAC when you pass 'cos they'll keep it when you register.
mad4x4
posted on 28/10/13 at 09:11 PM |
Depends when I did my SVA I got told to take all the plumbing foam off of the front arms as it wasn't "permanent" and promply
failed on shape edges that in protected..... So alot depends on the IVA tester.
Bit of Luck, be curtious and go with the flow.
If Worst comes to the Worst you will have a list of bad bits to fix....
Scot's do it better in Kilts.
40inches
posted on 28/10/13 at 09:19 PM |
That's right, it has all changed with IVA. All padding/covering has to either permanent, or if on a serviceable item removable without
destroying it, and the equivalent of OEM.
corrado vr6
posted on 28/10/13 at 09:26 PM |
Yep all pieces like that have removable closed cell foam wrapped around them and held on with a popper for serviceable use
scudderfish
posted on 28/10/13 at 09:47 PM |
The car?
Chris_Xtreme
posted on 28/10/13 at 10:13 PM |
files and emery paper in case you need to radius something a bit more.. in a friends case even the off the shelf indicators he had on the front wheel
arches ! a small file saved us.
skov
posted on 28/10/13 at 10:59 PM |
Flask of tea/coffee - my testers made themselves a brew or two but the gits never offered me one!
Acc8braman
posted on 29/10/13 at 08:28 AM |
Can't help with advice, but all the best with the test today. Be proud of what you have created ![](/images//smilies/smile.gif)
Slater
posted on 29/10/13 at 10:18 AM |
elastic bands.
These saved me from a fail. During SVA test I had to run into the nearest office and beg the receptionist to give me 6 red elastic bands. This was on
the advice from Mark at MAC#1, Used them for a throttle return spring on the carbs. and it passed!!!!!!!!!!!!!!!
Also wheel nut spanner, he might want to check the stud threads have enough threads engauged.
[Edited on 29/10/13 by Slater]
Lightning
posted on 29/10/13 at 01:13 PM |
If it was Exeter.....cakes, Byron loves cakes
posted on 29/10/13 at 01:21 PM |
Depending on how nervous you are, a packet of Imodium ![](/images//smilies/wink.gif)
adithorp
posted on 29/10/13 at 04:23 PM |
The suspence is killing me. Are you drowning your sorrows or celibrating?
http://jpsc.org.uk/forum/
corrado vr6
posted on 29/10/13 at 05:57 PM |
It failed unfortunately
I've started another post as wasn't sure if everyone would look back here to see how I got on
Here's the linky dink
http://www.locostbuilders.co.uk/forum/29/viewthread.php?tid=186265&page=1?#pid1567743
Thanks for asking
