daniel mason
posted on 1/2/14 at 04:29 PM |
m6 female rose joint with 8mm eye! do they exist
am after a right hand thread, m6 female rosejoint, but need to pass an m8 bolt through the eyelet! any ideas as ebay and mcgill motorsport not
successful
daniel mason
posted on 1/2/14 at 04:40 PM |
or a short m8 male threaded bolt with a 6mm threaded insert in the end!
Myke 2463
posted on 1/2/14 at 04:42 PM |
All the ones we use at work are the same both ends, never seen odd ones.
Be Lucky Mike.
gremlin1234
posted on 1/2/14 at 05:16 PM |
would these do?
http://www.ebay.co.uk/itm/M8-M6-x-12mm-STEEL-THREAD-ADAPTER-10pcs-/330935887561
blakep82
posted on 1/2/14 at 05:24 PM |
Well you do get 5/8" threads with 1/2" holes, but they're the only different sized ones I've seen, but I wouldnt say its
impossible
________________________
minitici
posted on 1/2/14 at 05:26 PM |
If it is for your Flatshifter gear sensor - why don't you just bush the gear lever hole down to 6mm and fit a 6mm bolt through the eye of the
rod end?
posted on 1/2/14 at 05:59 PM |
successful
No. I tried to find some for Rover 75 handbrake compensator upgrades.
You can get ones where the eye die is smaller than the shank but not the other way round and only in some sizes.
daniel mason
posted on 1/2/14 at 06:21 PM |
i could bush the lever down from 8mm to 6mm as long as it still allows the rod end to sit flush with the lever as the angle of the actuator is just
about ok as it is,but its tight.it would be out of line if the bush were to stick out more than 1-2mm
daniel mason
posted on 1/2/14 at 06:54 PM |
found some at memfast! 12mm long, 8x 1.25mm outer, 6x 1mm internal
