r1_pete
posted on 15/4/14 at 09:04 AM |
Wtd brake disc machining
Can anyone help, or know anyone who could machine a brake disc down in diameter? my lathe just isn't big enough.
I need 1 motorcycle disc reducing in diameter from 295mm to 280mm.
Sheffield area would be good.
Cheers.
MikeR
posted on 15/4/14 at 09:36 AM |
Claretoo isn't exactly local but the last time I was round (couple of years ago) she had a gap bed lathe & had machined flywheels.
May be a backup option.
loggyboy
posted on 15/4/14 at 10:11 AM |
Bolt it to a dril and get the angle grinder out
Mistral Motorsport
rodgling
posted on 15/4/14 at 10:25 AM |
As above, mount to a wheel hub and use an angle grinder - I've done this to take a few mm diameter off my front hubs, works fine if you
don't mind a bit of unevenness.
coyoteboy
posted on 15/4/14 at 11:44 AM |
Yes I've used a spinning part, spinning grinder process a couple of times to produce lovely round items - works quite well. Work holding is a
bit difficult at times though.
designer
posted on 15/4/14 at 12:53 PM |
Local machine shop will easily sort it.
r1_pete
posted on 15/4/14 at 02:49 PM |
Cheers guys, I had thought about bolting it up into the swing arm and seeing if I could rig a cutter up, guess I could annoy the neighbours with an
hour of two's angle grinding.......
coyoteboy
posted on 16/4/14 at 12:46 PM |
I'm finding it harder and harder to find a local machine shop willing to do stuff for cheap prices - they all want reasonable prices for half an
hours work, damnit.
Trollyjack
posted on 16/4/14 at 02:03 PM |
Hi
I have access to a leath at work I could do it for you.
But going away tomorrow not back till tuesday.
I'm in Sherburn in Elmet east of Leeds towards Selby.
U2u me If I can help
TrollyJack
