Author: Subject: Machining in Reading/Abingdon/Basingstoke area
OliilO
posted on 23/6/14 at 07:46 PM Reply With Quote
Does anyone have any recommendations for somewhere to do a bit of machining in the Reading/Basingstoke/Abingdon area or has a lathe and would be willing to do a small job in exchange for some beer tokens?
All I need is to turn down 5-10mm of the mounts on my steering rack so I am able to lower it a bit and eliminate some bump steering currently have.
Thanks,
Oli
mark chandler
posted on 23/6/14 at 08:08 PM Reply With Quote
Come around mine, Oliilo I have an old lathe that's not good for precise work but fine for your needs
Bring the car and set it up, no need to just bring the bushes.
[Edited on 23/6/14 by mark chandler]
OliilO
posted on 23/6/14 at 08:40 PM Reply With Quote
Thanks for the offer Mark, that would be great.
It's got a sierra rack, so will need to take the rack out and then turn a bit of the mounting surface if that sounds doable?
I'll send you a message a bit later in the week when I've got a better idea of what I'm doing this week and next. It'd be good to have a look at the turbo setup on your car too.
