bi22le
posted on 18/7/14 at 10:02 PM |
WTD: Alloy polo rad and 19 row oil cooler
My car was seriously overheating today and following advice from Elite Motorsport (Eddie99) I need to step up my cooling.
I have a stock Polo rad so would like a more efficient alloy version.
I also need to step up my oil cooler. I would like a 19 Row, any fixing size considered.
Thanks.
Please read my ring story:
Myke 2463
posted on 19/7/14 at 09:06 AM |
Give this some consideration bay 221495476062
Built in oil cooler and can cool V8's Land Rover Discovery MKI 2.5tdi Radiator
Be Lucky Mike.
INDY BIRD
posted on 19/7/14 at 09:36 AM |
Well hope you still had a good day?
Rally designs do one if you are not already aware? Probably the cheapest all alloy one as a direct replacement,
Hope you had a good track day I do like rockingham
Sean
bi22le
posted on 19/7/14 at 10:37 AM |
that is interesting. Has anybody used this type of thing on a track focused 7? Does it even fit in the nose cone?
rodgling
posted on 19/7/14 at 11:05 AM |
I have a 19 row Radtec oil cooler available, 330 x 50 x 150 mm, AN -10 fittings, £50.
bi22le
posted on 19/7/14 at 12:34 PM |
Condition?
Pics?
Benzo
posted on 19/7/14 at 06:11 PM |
I have a black mocal 13row cooler, done two race days.
Decided to remove it because it's not required and oil is running too cold.
It cost me £90 from demon tweeks.
I'd take £45 including postage.
bi22le
posted on 19/7/14 at 06:24 PM |
rodgling's turns out to be only a 12 row and I really need as big as possible as my oil is running hot hot!!
what's the dimensions. I may consider a 13 row if it is nice and wide.
rodgling
posted on 19/7/14 at 06:30 PM |
Out of interest, what size is your current cooler, and where is it mounted? It might just be a case of getting more airflow to your existing cooler?
Benzo
posted on 19/7/14 at 08:37 PM |
Mocal Cooler is 260x100mm
