Author: Subject: K Series into Striker parts wanted
lsdweb
posted on 1/1/15 at 01:47 PM Reply With Quote
Hi All
It looks like I'm going to be dropping a K series into a Striker so I'll be looking for the following parts -
Bell housing
Flywheel
Exhaust manifold
Engine mounts
Anything else you guys can think of!
I'm not on Blatchat but if somebody could either have a look on there for me or post on there on my behalf I would be most grateful!
Many thanks
Wyn
[Edited on 1/1/15 by lsdweb]
daniel mason
posted on 1/1/15 at 01:56 PM Reply With Quote
6 speed caterham box!
[Edited on 1/1/15 by daniel mason]
lsdweb
posted on 1/1/15 at 02:01 PM Reply With Quote
It currently has a Type 9 but I'm open to suggestions!
daniel mason
posted on 1/1/15 at 02:06 PM Reply With Quote
There's a cracking striker complete in for sale section! If selling up and buying is an option
lsdweb
posted on 1/1/15 at 02:13 PM Reply With Quote
Thanks Daniel. I had seen that but it's out of my budget! And I'm building a 1400 :-)
daniel mason
posted on 1/1/15 at 02:20 PM Reply With Quote
You will like the 1400! They love to be revved. Almost as much as the 1600. If anything you'll want more power very soon after the install unless performance isn't an issue. 1600 is a decent step up in performance
lsdweb
posted on 1/1/15 at 02:29 PM Reply With Quote
Mine should rev to 9500 :-)
scimjim
posted on 1/1/15 at 03:56 PM Reply With Quote
I have a spare bellhousing - also manifold, possibly flywheel - can check and photograph tomorrow.
liam.mccaffrey
posted on 1/1/15 at 05:18 PM Reply With Quote
I have a complete 1600 engine and box free to a good home. just collect it.
Build Blog
Build Photo Album
lsdweb
posted on 1/1/15 at 07:29 PM Reply With Quote
Thanks guys. I've now found the bits I need courtesy of a LCBer. Engine is courtesy of Dave Andrews :-)
daniel mason
posted on 1/1/15 at 07:36 PM Reply With Quote
Dva 1400 will be spot on!
lsdweb
posted on 1/1/15 at 07:43 PM Reply With Quote
He's never built one like this before!
Short stroke - 1350cc (ish).
82.5 mm block / liners that normally make 1900cc.
VVC head (VVC blanked off) polished and ported.
1444 cams
Jenvey DTH throttle bodies
Emerald ECU
Custom forged pistons
We're hoping it will go well!
femster87
posted on 1/1/15 at 07:55 PM Reply With Quote
Wyn, that sounds like a great little engine. I will love to have mine built up to similar spec. Can you let me know what its like when its up and running
lsdweb
posted on 1/1/15 at 09:54 PM Reply With Quote
Will do Femi - I'll let you know how much it cost too!
TimC
posted on 1/1/15 at 10:12 PM Reply With Quote
Any chance of one of your infamous abandoned blogs to cover the build?
lsdweb
posted on 1/1/15 at 10:20 PM Reply With Quote
No wonder you got kicked out of Wales! :-)
daniel mason
posted on 1/1/15 at 10:25 PM Reply With Quote
One thing for sure. The dva motor will cost! But they are good
femster87
posted on 1/1/15 at 10:27 PM Reply With Quote
Cheers. Not sure I look forward to the cost. But I think it will make a lovely engine in the sprite.
lsdweb
posted on 1/1/15 at 10:29 PM Reply With Quote
Apart from the custom pistons, crank and rods it's a pretty standard DVA engine :-)
daniel mason
posted on 1/1/15 at 10:53 PM Reply With Quote
It's the jenveys and emerald which cost! It'll all be worth it when it's screaming along
