johnemms
posted on 2/1/15 at 02:31 PM |
Odometer - Speedo
Hi Guys.. Changed my dash over to a nice set of clocks.. however.. my speedo has trip 1 & 2 but no odometer..
My insurance says 'must have odometer' as I use limited mileage insurance..
I want to keep my clocks so I'm looking for a - simple - small digital speedo with odometer.
Can anyone suggest or have one that I can tag onto the pulse output on my type 9 box..
cheers
My Clocks Video Link
[Edited on 2/1/15 by johnemms]
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
russbost
posted on 2/1/15 at 04:27 PM |
Cheapest Acewell that will run from a gearbox transducer would be the 3254 at £118.99 + P & P, as usual can give discount to lcb if we are dealing
direct. It's quite a sophisticated unit tho' so actually does a lot more than just speedo/tacho/odo.
Stot
posted on 2/1/15 at 04:40 PM |
Is there an OEM speedo/odometer you could harvest and have visible under the bonnet rather than on your dash?
Stot
gremlin1234
posted on 2/1/15 at 06:20 PM |
a while ago, there was a thread
http://www.locostbuilders.co.uk/viewthread.php?tid=190357&page=1
which shows a simple industrial counter can be used for odometer functions.
but as Stot suggests another under the bonnet would work, - even use the one you have taken out!
johnemms
posted on 2/1/15 at 07:06 PM |
I think this Acewell 3100 is about as cheap as i can find..
Acewell 3100 Digital Dash Speedo Tacho clocks Motorcycle Trike Quad Kitcar BNIB
steve m
posted on 2/1/15 at 07:34 PM |
I used to use a push bike speedo,(£7 ) and as you calibrate it yourself, you could make it read what ever you want
but ive NEVER gone over the 5k allowance I pay for
steve
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
blakep82
posted on 2/1/15 at 09:57 PM |
Spa design speedometer is small and has a odometer, could be mounted hidden away somewhere, under the dash, in the engine compartment etc. Odometer
function is there, just not on you main gauges?
http://www.spa-uk.co.uk/Product/Digital%20Speedometer
________________________
