Dopdog
posted on 12/5/15 at 05:43 PM |
Gen 1 Extreme Engines Hayabusa dry sump full package
I have for sale as title a complete engine package that at the moment is installed in my fury. It will not be removed until a sale is agreed so it can
be heard running. The engine spec is below.
It will come with
the ecu, wiring loom if wanted, exhaust manifold again if wanted.
New Glpro with atre (blue)
New power commander 5 never fitted.
I have the receipt from extreme engines and it was rebuilt on 23-04-12.
Since being built it did 2 events in Scotland then I have driven it 4 times.
it is the stage 1 tune
full gas flow on head
regrind valves new v-stem oil seals
Kent Suzuki 24 spec cams with APE adjustable sprockets.
Ross 81mm high comp pistons
new cam chain
all new selector forks and selector shaft
new 3/4th double gear
1st gear thrust washer
Pair of undercut gears 6th and 2nd
new output shaft
Rear selector shaft
Flat billet sump
PACE twin scavenge dry sump pump
Aluminium oil tank
Oil cooler
Large bore Aeroquip pipe and fittings throughout
Remote clutch slave.
New starter clutch
Billet starter cover and idle gear.
New ITG filter.
This is a great engine and if not sold will just keep it, but the reason for selling is to move to another class.
£3750 ono
daniel mason
posted on 12/5/15 at 07:31 PM |
That's a great package to drop into a kit hasstle free!
mark chandler
posted on 12/5/15 at 10:01 PM |
So what's the plan Simon, going CEC .
it's tempting for sure after watching that Westfield leap off the line.
Dopdog
posted on 13/5/15 at 08:33 AM |
Top secret mission Mark
Autoflock Motorsport
posted on 13/5/15 at 10:23 AM |
out of interest wat sor of bhp/ftlb is this engine producing?
Sounds an awsome piece of kit
Kind regards
Raj
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=183445
Dopdog
posted on 13/5/15 at 12:24 PM |
I am not sure to be honest as I have not had it on the rollers but I can tell you it pulls like a train and revs very clean
dilley
posted on 10/6/15 at 12:20 PM |
I may be interested, I really would like an idea of hp....
Dopdog
posted on 10/6/15 at 03:30 PM |
Sorry should have posted, engine not for sale anymore.
