<<  1    2  >>
Author: Subject: Superchargers - CBR900
Matt21
posted on 5/6/15 at 08:30 AM Reply With Quote
Has anyone had any experience with a supercharger on a cbr900? or any other bike engine for that matter?
I've got the opportunity to buy a rotrex c15 kit, my plan was to turbo, but this is very very tempting!
I cant find any info on the web about the cbr being supercharged though, which isn't too good for me
jeffw
posted on 5/6/15 at 08:49 AM Reply With Quote
Look at the TTS performance site detailing all the bikes and BEC they do
http://www.tts-performance.co.uk/
mark chandler
posted on 5/6/15 at 06:01 PM Reply With Quote
I guess the challenge is getting a drive off the crank that can support 30hp
bi22le
posted on 5/6/15 at 06:10 PM Reply With Quote
Ill swap you the rotrex for an eaton m62. . .
Please read my ring story:
Matt21
posted on 5/6/15 at 08:02 PM Reply With Quote
Judging by that I assume the Rotrex is better than the Eaton.... haha
I'll keep the rotrex I think (when i buy it anyway) as its brand new!
I had a look on TTS about the Rotrex C15, but there is no kit for the CBR900 or any engine with carbs from what I know.
The guy im buying off bought it for a cbr900 so i guess he did his research first, i'll pick his brains when i go and see him, just thought id ask here and see if there was anyone with knowledge
I'd like to check all the pulley sizes etc were correct incase he hasnt done his research! but we will see!
bi22le
posted on 5/6/15 at 11:19 PM Reply With Quote
Better and costs alot more! ! They are not even in the same ball park of products.
I would love a rotrex but can't front the cost when just the charger is the same cost as the whole build using an Eaton!
Matt21
posted on 9/6/15 at 11:37 AM Reply With Quote
Got it!!
It was fitted for 2 drives! so virtually new
Rotrex C15 supercharger (I believe a C15-60, though there is only C15 stamped on it)
Mocal oil cooler
Oil tank (it runs off its own oil supply rather than the engines)
Oil filter
Ford rs turbo intercooler
1/2litre of rotrex traction fluid
60mm pulleys
toothed belt (not the ribbed v belts)
shaft that comes off the crank to the bottom pulley
£380!!!
I just need to machine the timing inspection cover to fit an oil seal for the shaft and knock up some brackets to hold the charger (which is getting done at the moment by a friend.
Inlet plenum, intercooler pipework, lock up clutch, fuel pump and pressure reg and I think i'll be somewhere near running! maybe a bit of dyno time and new jets for the carbs.... but I dont know yet
[Edited on 9/6/15 by Matt21]
OliilO
posted on 9/6/15 at 11:54 AM Reply With Quote
Sounds like a bargain.
Where do you take the supercharger drive from?
Matt21
posted on 9/6/15 at 07:35 PM Reply With Quote
I need to machine the timing inspection cover to hold an oil seal, then a shaft runs through that and bolts up to the end of the crank shaft, with 4 little pins that fit into 4 drilled holes on the timing disc, the pulley sits on the other end.
anyone know if I need to drop the compression?
how much by? how thick would the spacer need to be?
and where do I get one from?!
can I get, say a 1mm aluminium spacer laser cut and put a standard head gasket either side? should give me 1.5mm extra? too much, too little?
tts reckon it will be making 14psi boost with the current pulleys :| im not sure how right this is yet.....
bi22le
posted on 9/6/15 at 07:44 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=180039
I had this in my book marks for when i was going to lower my CR.
Coincidently its also about a turbo zx9 so maybe of use.
It should answer your question about head gaskets. The company is called Faraday engineering, phone them, they have a calculator to work it out.
[Edited on 9/6/15 by bi22le]
posted on 9/6/15 at 09:26 PM Reply With Quote
Ferriday Engineering.
I wouldn't have thought driving a supercharger through the crank trigger wheel is going to be a very reliable solution however.
[Edited on 9/6/15 by MikeRJ]
hobbsy
posted on 10/6/15 at 07:25 AM Reply With Quote
I have a C15 Rotrex also sat waiting for find its way on to a bike engine
There's a chap called Winston who sprints an R1 (5VY) engined Caterham who uses the same charger and I think it takes its drive from there.
Look here as well for inspiration
http://www.mountainperformance.com/rx1%20supercharger%20pics.htm
Matt21
posted on 10/6/15 at 11:36 AM Reply With Quote
Mike, can you explain why you don't think its such a good idea to run it off the end of the crank? I'd like to see a problem before I do something silly!
I'm not sure where else it could be run off myself. the shaft is only around 4inches in length including the pulley so there wont be a great deal of stress added
hobbsy, do you have any more info that would be helpful to me? or any idea on what you are planning on doing with yours, boost pressure, gaskets, carbs etc etc?
Matt21
posted on 10/6/15 at 04:11 PM Reply With Quote
Another few questions....
what happens when I'm at 8k rpm and a take my foot off the throttle? I'll still have, lets say, 6psi of boost trying to get into my engine? will this just 'stall' the supercharger?
do I need to fit a 'dump valve' to get rid of that pressure that cant get into the engine?
can the dump valve also be used to regulate the boost pressure? ie, anything over 8psi gets dumped as I'm still accelerating?
is a dump valve different to a recirc vavle?
I had a skim through the rotrex data sheet and it says to use a recirc vavle between the charger and the carbs, that needs back to the inlet of the charger? wont this just keep putting the same pressure through to my carbs when I'm off throttle?
I think they run off a vacuum line also... I don't have a vacuum anywhere I don't think?!
Matt21
posted on 20/6/15 at 11:49 AM Reply With Quote
Can anyone help with the vacuum lines?
Small update on the progress.
My mate has done a grand job of machining the crank cover to take an oil seal for the shaft to run through
And also modified the timing ring to hold the supercharger shaft so that it doesn't 'slip'
I just need a figure out how to tighten the crank cap up now as the nut is no longer on it! I'm sure I'll find a way.
I think my shopping list is complete and I'll just start ordering bits and pieces slowly.
First up is a lock up clutch!
Autoflock Motorsport
posted on 23/6/15 at 12:21 PM Reply With Quote
my conversion will be very similar, that too is just an extended bolt which protrudes out of the casing allowing the fitment of the drive pulley, a dump valve will vent unwanted boost off (to air or recirc)
I will try and find a useful link which got me into it in the first place.
That is a cracking price, ive hopefully sorted a deal out for the supercharger and drive kit for 1500 euros
Kind regards
Raj
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=183445
posted on 23/6/15 at 12:36 PM Reply With Quote
here are a few pics from my research
Here is the srandard cover removed showing the m10 bolt which needs to be remade with another side to it to stick out of the casing
This is the plate being machined to hold the supercharger and allow a longer m10 bolt to driver the pulley
Assembled
I have a spread sheet which I have created which helps you design the driver pulley to give optimum performance, so going off my power graph I can work out how to use the main areas of my powerband to drive the supercharger and hold its in it efficiency range as long as possible according to the rotrex graph.
Hope this helps :-)
Keep us all posted with your progress
Kind regards
Raj
posted on 23/6/15 at 12:54 PM Reply With Quote
Sorry, I missed this. Driving it off the end of the crank is not the problem, that's by far the best and most obvious place to drive it from. My concern would be whether the relatively flimsy trigger wheel is up to the job of transmitting the (very significant) amount of power that a supercharger requires.
Matt21
posted on 25/6/15 at 06:49 AM Reply With Quote
Mike - After getting the parts back off my mate, I'm pretty sure its going to be solid once its all bolts up! the shaft isn't very long so there wont be much leverage, and the bolt fits in tight to hold it well!
That's a very neat mount! I'm going to have to make a bracket that will hopefully fasten on to the engine mounts.
I've been told by a supplier that a Forge 008 DV will be suitable for my set up, but I still don't know about the vacuum! surely my engine is supposed to have vacuum pipes somewhere?
CosKev3
posted on 25/6/15 at 01:11 PM Reply With Quote
From talking to Dale at Bailey Performance the other week going charged on carbs is a pita to get set up properly.
Getting the carbs to be sealed is awkward, then you have to take them off to re-jet them everytime!
mark chandler
posted on 25/6/15 at 03:25 PM Reply With Quote
No vacumn pipes on an early blade engine, you can however use the carb balancing tapped holes in the block just get some LPG injector nozzles for a few pennies to screw in for your tube to hang off of.
Matt21
posted on 26/6/15 at 01:40 PM Reply With Quote
Kev - I had sent an email to holeshot racing, they told me to post just my carbs to them, and they would send that back to me after theyve done something to them and they would work?! I'm not sure how they know they will run right without a rolling road, but they said it was fine
Mark - would that provide me with enough vacuum to open a dump valve up?
Dopdog
posted on 26/6/15 at 01:54 PM Reply With Quote
TTS is the way to go they put the supercharger on top of the gearbox for car installs, very tidy.
DANMAN
posted on 13/7/15 at 10:41 AM Reply With Quote
Super excited to see this post. I had been contemplating the same thing for my Blade engine but couldn't find a lot of info on it, will keep an eye on this thread so please keep us all updated!!!
Matt21
posted on 14/7/15 at 12:34 PM Reply With Quote
Well.... I went to fit the crank cover onto a spare engine to check that things went together OK. Only to find that the crank shaft is NOWHERE near the center of the bloody timing hole!!!!
The only thing I can thing of doing is welding a plate into the hole instead of the disc and having a hole machined into it for the oil seal. How to set the timing after that I don't know!
Any on got any other suggestions?
<<  1    2  >>
