Author: Subject: wishbone failure
ruskino80
posted on 19/9/15 at 06:43 AM Reply With Quote
wishbone failure
Just came across this on mk indys facebook.
https://www.facebook.com/photo.php?fbid=10153044376190308&set=pcb.10153106888593314&type=1&relevant_count=4
theprisioner
posted on 19/9/15 at 08:07 AM Reply With Quote
If it is broken like that, is it because the tube it is made out of has a seam?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Talon Motorsport
posted on 19/9/15 at 09:06 AM Reply With Quote
It looks a bit on thin side to me maybe 1.2-1.6mm? Personally I like to go for the overkill approach it seems to be safer in the long run, I make sure all the seams on my bush tubes have the 'leg' section welded across it.
40inches
posted on 19/9/15 at 09:34 AM Reply With Quote
Usual cause, in the past, has been the outer tube being tight in the brackets, not allowing the bush to pivot on the central tube.
Slimy38
posted on 19/9/15 at 11:56 AM Reply With Quote
The full post suggests they had checked all the joints earlier as a possible cause of another fault, but they were found to be free.
Having said that, I don't understand why the inner face is so mucky. That does suggest the bush tube and the bush weren't in permanent contact, and as you say it meant the bush tube was revolving around the bush rather than the bush revolving around the central crush tube.
liam.mccaffrey
posted on 19/9/15 at 12:30 PM Reply With Quote
Heat affected zone failure.
Build Blog
Build Photo Album
posted on 19/9/15 at 02:56 PM Reply With Quote
It's undoubtedly failed at the HAZ since that's the weak point, but that's not the actual cause otherwise the entire chassis would fall apart.
Probably either a steel crush tube that rusted and seized in the bush, or the bush was a bit too wide for the chassis brackets and caused binding with the bolt tightened up. Those two problems have been the primary cause of numerous failures like this.
myke pocock
posted on 19/9/15 at 03:22 PM Reply With Quote
When I made my bush tubes I used thick wall seamless and skimmed the ID to the required size meaning I got the ID I wanted and probably a bit thicker wall thickness as well.
