Author: Subject: Zetec alloy pulley
richard munnis
posted on 27/11/15 at 03:54 PM Reply With Quote
Zetec alloy pulley
Hi Folks
Looking a alloy water pump pulley to run the reverse impellor with ribbed type pulley so it would end up same as silver top one have seen them on other sites just wondering who makes them, cheers Richard
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 27/11/15 at 06:14 PM Reply With Quote
Do you mean an idler. A new pulley, ally or not will not make the pump go the other way. I use an old timing belt tensioner suitably mounted and run the back of a belt on it. SBD do a kit if you cant knock your own up.....
richard munnis
posted on 28/11/15 at 08:33 AM Reply With Quote
No have bought a reverse impellor and see a fellow makes alloy ribbed pulleys on another site to match but can't pm him for some reason
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 28/11/15 at 09:03 AM Reply With Quote
Sorry, I read it that you wanted to reverse the impeller. Have you tried Burtons. Where did you buy the reversed impeller.....
richard munnis
posted on 28/11/15 at 09:48 AM Reply With Quote
Alloy one on ebay look under rwd zetec they come up cheers Richard
