jameskett
posted on 8/5/16 at 07:19 PM |
zetec oil leak from filler cap
Finally got my Fury ready to drive, so I went for a fairly gently 10 mile round trip, when I got back I found quite a good leak of oil all around the
filler cap and running down the rear/side of the engine, down the bellhousing. Engine is a 1994 Silvertop 2.0 Zetec with Jenvey TBs.
I have the cam-cover breather t-ed into a pipe from the crank breather, which then leads to a catch tank, which has a small breather filter on its
second outlet. The catch can has some clear water in it but not really any oil, although I can see some signs of fumes coming in from the engine side
when its running. The water I assume is condensation as the car has not run for more than a few minutes at a time since last year as I rebuilt it.
There is no rubber seal on the oil filler cap, not sure if there should be. Also I noticed there is no baffle plate above the camshaft under the oil
filler neck, again I'm not sure if there should be?
Aside from this it ran perfectly , oil is clear and still full , temperature sat at about 90ish on the gauge , coolant is clear blue etc...
Can anyone suggest what could be causing this leak?
I wondered whether there was too much pressure in the catch can or the filter was too restrictive or something, so next time I'll leave the
catch-can cap off it and see what happens , but perhaps do I need to modify the crank breather valve or similar, I've seen it mentioned in
places.
thanks
James
ian locostzx9rc2
posted on 8/5/16 at 07:39 PM |
I'm pretty sure it should have an oil seal on the cap .
madteg
posted on 8/5/16 at 07:44 PM |
I seem to remember there is a splash plate under the filler neck with a wire gauze trapped in it. Also there is a rubber seal on the filler cap
PJCTHolmes
posted on 9/5/16 at 11:00 AM |
Oil filler cap leak
On my 1.8 and 2.0 zetec there is no splash guard where the
cap is. Also I don't remember there being a rubber seal on
the cap either, it has a tapered fit where it meets the cam
cover neck. The cap has a ratchet mechanism, is it broken?
Maybe try another cap to check if you can.
jameskett
posted on 9/5/16 at 11:26 AM |
The cap ratchet works OK.
Spoken to Burton Power and although they can't supply a new cap they suggest I have the breather layout wrong by T-ing the 2 breathers into 1,
they say it should be a pipe per breather to the catch can, with just 1 pipe it will be 1/2ing the breather volume, so I'll try that next and
see what happens.
PJCTHolmes
posted on 9/5/16 at 11:37 AM |
Good info, I'm just about to put a catch tank on mine!
avagolen
posted on 9/5/16 at 06:03 PM |
I have a similar setup.
I have 'T'd the 2 breather pipes into 1 then to the catch tank. No problems here. Over 1700 miles covered.
The valve is removed from the crankcase breather and the pipes are set so that any oil that collects in the
hoses can drain into the crankcase.
I would try the breather cap removal first just in case the catch tank is pressurising.
jameskett
posted on 9/5/16 at 06:31 PM |
Well I removed the existing catch can & pipes , and ran 2 1/2inch ID hoses from the breathers, and stuck each into an aluminium drinks bottle
gaffer taped to the bulkhead, then went for a similar drive to yesterday, and there's no sign of any oil from the filler cap today so fingers
crossed that's sorted it. I won't know for sure until I've driven the car further and harder, but given the mess it made yesterday
on a similar drive it looks good so far.
I'll make up a proper catch tank with 2 large inlets and a breather that can sit on the bulkhead behind the engine, that should look neater than
a gaffer taped Hello Kitty drink bottle
