Magnus 2074
| posted on 15/7/16 at 09:46 PM |
WTB: Desperately in need for Sierra stub axle!
Hello,
I'm desperately looking for a left side Ford Sierra stub axle. This part seems impossible to find, and I would appreciate any help in this
matter.
Can't drive my car until I find this part.
Which Sierra models had this odd stub axle? If anyone has one for sale I'll buy it at once.
Thanks!
Borrowed a picture on the the axle I'm looking for (the left one)
/Magnus
minitici
| posted on 16/7/16 at 02:18 PM |
eBay Item
You can buy a brand new pair of 100mm stub axles with hub nuts from J&R Driveshafts for £39.99 + postage
ebay link to their listing is above
Just had another look at your picture and don't recognise the one on the left.
Does the one on the right fit (same splines)?
If so you could possibly fit a spacer sleeve to a standard one??
[Edited on 16/7/16 by minitici]
loggyboy
| posted on 16/7/16 at 03:32 PM |
I believe they are from a 4x4 with drum brakes
Mistral Motorsport
Magnus 2074
| posted on 17/7/16 at 09:38 PM |
A spacer sleeve should be possible, but I dont have the tools to fabricate one
It has to have splines on the inside, otherwhise the bearing would rotate with the spacer sleeve.
I have managed to find a couple of drive shafts from 4x4 Sierras, but all of them had push-in shafts. The bolted one seems very rare.
My best option if I dont locate the correct stub-axle is to replace the stubs, bearing and wheel hubs to the other model.
| posted on 18/7/16 at 08:10 AM |
Does the stub to the right have an ABS ring on it too?
loggyboy
| posted on 18/7/16 at 08:40 AM |
2 further options - neither 'simple'. but 'future proofs' any further replacement parts needed.
Switch to Discs, use the stub on the right and change hubs, carriers, calipers etc.
Switch to push in shafts. Means replacing Diff (or diff flanges/input stubs), new shafts, but 'should' mean you can retain drums and
current bearing carriers.
The set up you have is actually what I wanted on mine as I wanted to retain drums and have bolt on shafts, but getting the correct arrangement
of parts from rarer cars pushed me to having the common bolt on/disc setup.
[Edited on 18-7-16 by loggyboy]
Mistral Motorsport
RWD Focus
| posted on 18/7/16 at 11:27 AM |
Sorry to hijack the thread but i have an option for you see link below.
http://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=204961
Magnus 2074
| posted on 18/7/16 at 11:43 AM |
I have a Ford 7,5" with a Quaife ATB differential, so a new diff with push-in shafts is not an option I'm afraid.
I already have disc brakes. But the best best option seems to be buying new stubs, carriers and hubs and cut away the caliper mounts.
My rear brakes
baz-R
| posted on 27/7/16 at 06:46 AM |
All 4x4 Sierras had 7" viscose Lsd's so not push fit shafts.
Some super rare xr4's had bolt on lobro shafts and drum breaks apparently but never seen them
Mopple
| posted on 27/7/16 at 10:27 AM |
An option would be to rethread the stub axle.
Original thread is M22x1,5, it can be rethreaded to M20x1,5 or M18x1,5 thread and to use according fine thread nylock nuts for locking. M20 nut needs
some trimming to get correct locking as the original nut height is 17,2 mm.
Magnus 2074
| posted on 27/7/16 at 11:38 AM |
The picture with the damaged threads was a borrowed picture.
Mine was not repairable.
But I have found and bought an new stub axle from an TVR with the correct Sierra parts.
