the_big_1
| posted on 29/9/16 at 10:06 AM |
Sierra Uprights or Swap for Cortina
Hi guys,
I have a full set of front Cortina uprights including hub, callipers, discs carrier etc. but I need a Sierra setup.
Happy to swap if anyone would like to or buy the Sierra set up?
kingster996
| posted on 29/9/16 at 09:03 PM |
I have some Sierra uprights, hubs, 265mm solid discs, wishbones and cycle wing brackets I removed from my Westfield SDV when I recently converted to
Westfield widetrack. No calipers as I used them, though I do have the Wilwood brackets so you could use Wilwood radials.
The cycle wing brackets include inserts for drag link (top ball joint) and I also have MK mushroom inserts.
Not considered the cost yet, will have a ponder or feel free to u2u an offer.
Can post pics
I used to be indecisive, but now I'm not so sure
the_big_1
| posted on 30/9/16 at 10:39 AM |
Sure post them up please and an idea of price if you could.
Cheers!
kingster996
| posted on 30/9/16 at 12:32 PM |
This is straight after taking them off the car, so still got some road grime on them - but you can see how the Westfield cycle wings fit. I also
fitted some longer studs as once the discs are on, std studs leave minimal thread engagement with alloy wheels.
Discs are 257mm not 265mm - they were part of this kit from RD - so you can
buy nice new 4pot Powerlites for £89 each and have some pretty decent brakes. Not sure if the discs would suit other setups, so selling with the
adaptors only.
Price?
Uprights & hubs (with new mushroom inserts and used ball joints) £70
Discs & Wilwood Powerlite fitting kit £40 (fitting kit is that price plus vat from RD)
Cycle wing brackets £30
All plus post - which might be a lot due to weight!
CosKev3
| posted on 30/9/16 at 12:45 PM |
OT Chris but what pads does that kit in your link come with?
kingster996
| posted on 30/9/16 at 12:48 PM |
The kit doesn't come with pads - I went for Mintex1144's
CosKev3
| posted on 30/9/16 at 12:51 PM |
Ah right cheers,thought it looked too cheap to include pads TBH!
