Mark100
posted on 30/11/16 at 05:49 PM |
Neoprene
Hi I have neoprene rubber to put pads on my seats but cutting it to shape is leaveing a ruff edge
any ideas how are you lot shapeing this stuff ????????????
leon51274
posted on 30/11/16 at 06:15 PM |
Waterjet Mark, although I would of thought your arse would offer more than enough padding!
StevieB
posted on 30/11/16 at 06:16 PM |
I used a scalpel when I did mine.
Just go really slow and try and do it in one cut - if you go back and make a second pass you'll invariably leave a ragged edge.
bi22le
posted on 30/11/16 at 08:45 PM |
I would bind the edges. I have worked with Neoprene and if you dont add edging (webbing material) then it will delaminate.
Please read my ring story:
Andybarbet
posted on 30/11/16 at 09:12 PM |
I would try a 'hot knife' you can pick one up for £20. It shoyld give a clean cut & it will heat seal the edges.
posted on 1/12/16 at 09:06 AM |
We've used it at work and cut with a scalpel to get a clean edge. Ditto the "one cut" approach, cutting the same edge more than
once will leave a raggedy edge on it.
One other thought...does the seat manufacturer not supply pads for the seats? Pre-cut and probably a good fit too.
Matt21
posted on 1/12/16 at 12:05 PM |
Surely neoprene is going to offer next to no padding at all?
Unless its like an inch thick?!
Instagram: @matt211988
Photobucket
My YouTube
posted on 1/12/16 at 05:14 PM |
Can see your point re: padding, but neoprene may well help hold you in place better on a GRP seat
Mark100
posted on 1/12/16 at 08:13 PM |
Its for the grip more than the padding ill try scalpel and heat tomorow cheers
Hodor
posted on 6/1/17 at 03:23 PM |
How did this go? Interested to find out. What thickness of Neoprene did you use? I have a 50cm square of 12mm stuff that I bought to do the same,
but just sit on it for now, literally. Was intending to buy more to make pads for the back.
[Edited on 6/1/17 by Hodor]
johnH20
posted on 6/1/17 at 05:30 PM |
I use a neoprene 'pad' as an anti slip measure on a fibreglass seat, helps particularly under heavy braking. Mine is only 3 mm thick and
single faced with fabric, actually cut from an old wetsuit with a pair of sharp scissors. Edges are fine.
Mash
posted on 6/1/17 at 05:47 PM |
I bought an ex-army roll matt, about 10mm thick, double thickness under the cheeks, then covered seat with black stretch van wall carpet Not bad
result ![](/images//smilies/smile.gif)
rm0rgan
posted on 8/1/17 at 03:49 PM |
Save yourself the hassle...GRP/CARBON/KEVLAR/ALUMINIUM CAR SEAT PADS UNIVERSAL for Bucket Seat in BLACK
I have them fitted to my seats
![](/galpreviews/14469712_10153681091466734_2284690476313817712_n.jpg) ![Seat Pads](/gallery/14469712_10153681091466734_2284690476313817712_n.jpg) Seat Pads
Sigs are uncool.
