andyfiggy2002
posted on 15/12/16 at 11:06 PM |
canted carbs on blade
the age old dilema for BECs if u wanna do trackdays need to get noise down, problem is how do I get a non OEM airbox to fit under the bonnet to
address induction noise?
I have 38mm carbs on my 893cc blade that has so far run sweet with a sausage air filter. This got me thinking about canting carbs down a bit to lesson
the angle so a larger airbox will fit, the 4 rubber boots that hold the carbs to the head are straight rubber tubes but I can't find 38mm angled
ones on the interweb only 40mm angled ones for a 2002/2003 R1, question is will it affect performance of the engine or the operation of the float bowl
level if I fit these angular ones & secondly will I be able to do the jubilee clips up enough to take out the 2mm difference without the carbs
acting as though they're sitting on a slab of jelly???Yamaha YZF-R1 YZFR1 2002 2003 Carburettor Carb To Cyclinder Head
Rubbers Pack 4![](http://rover.ebay.com/roverimp/1/710-53481-19255-0/1?ff3=2&pub=5574934589&toolid=10001&campid=5336738914&customid=&item=123456&mpt=[CACHEBUSTER])
CosKev3
posted on 16/12/16 at 08:15 AM |
Are they Deffo angled?
As I'm sure they are straight the same as my early carbed R1 engine.
Could be a generic picture used on Ebay,also the listing details are incorrect as the 2002/2003 is fuel injected.
CosKev3
posted on 16/12/16 at 08:18 AM |
YAMAHA YZF R1 2002 2003 02 03 5PW RN09 THROTTLE BODIE RUBBER CLAMPS INTAKE DUCTS![](http://rover.ebay.com/roverimp/1/710-53481-19255-0/1?ff3=2&pub=5574934589&toolid=10001&campid=5336738914&customid=&item=123456&mpt=[CACHEBUSTER])
LBMEFM
posted on 16/12/16 at 08:21 AM |
I originally used a foam sausage but was never happy with it. So I fitted the original Blade air box by turning it upside down it then has clearance
under the bonnet and because it is designed for that engine it's perfectly balanced and I felt it gave the engine a better performance. I also
ran two flexible pipes from the intakes and up to a bracket to take in cool air from the bonnet scoop and fitted a s/steel sleeve with a mesh on the
opening I painted mine silver and put a K&N sticker on it just to bling it up a bit. Looks good and works well and is easy to fit.
andyfiggy2002
posted on 16/12/16 at 07:44 PM |
Ok thanks for info, anyone know of any other angled 38mm rubbers used on other bikes that I could consider?
CosKev3
posted on 16/12/16 at 08:13 PM |
How much room have you got above cars to bonnet?
If you can't do as above and rework the blade box a custom made one would be better imo than altering the carb angle.
avagolen
posted on 16/12/16 at 08:26 PM |
This is a picture of the carb rubbers I have used fro my ZX6R carbs. Ebay a couple of years ago.
38mm.
Angled and grooved which helps keep them on. These look similar....
Kawasaki GPZ 900 R ZX900A1 1984 Carb Carburettor to Head Rubbers Pack of 4
![](/galpreviews/carandrubbers.jpg) ![carbs](/gallery/carandrubbers.jpg) carbs
snapper
posted on 17/12/16 at 08:30 AM |
Or fluro lined silicon hoses but you will need Miklor clamps and fixed supports for carb to manifold/engine to stop them slipping off.
I have run carbs flat and level with no issues
I eat to survive
I drink to forget
andyfiggy2002
posted on 17/12/16 at 11:18 AM |
Ok , i will look for some silicone hose elbows just to bring the carbs down a bit
[Edited on 18/12/16 by andyfiggy2002]
