Author: Subject: Felt Washers
jimmyd
posted on 14/1/21 at 11:09 PM Reply With Quote
Felt Washers
You guys are great at turning up stuff, I’m having difficulty sourcing polyester felt washers ID 8mm OD 12mm Thickness 1.5mm. Only need six to replace on carb throttle shafts, manufacturer doesn’t list them and I’m not finding anywhere.
J
rf900rush
posted on 15/1/21 at 07:32 AM Reply With Quote
Try searching fibre washers
I found these thiknsess no shown
https://www.wickes.co.uk/Wickes-Fibre-Washers---8-x-12mm+2- x-19mm-Pack-of-10/p/421633
Or are they the fabic type rather than like plastic types
[Edited on 15/1/21 by rf900rush]
jimmyd
posted on 15/1/21 at 07:59 AM Reply With Quote
Thanks but felt (like woollen) rather than fibre required
posted on 15/1/21 at 08:16 AM Reply With Quote
Is it not possible to make your own?
A 12 mm and 8mm hole punch with some 1.5 mm thick felt?
A wooden jig to align the holes if you cannot do it by eye and hole position is critical.
You would punch he inner hole first. Note you need to test the material to see if it copes with the heat.
What is the purpose of them? Are they to hold oil for lubrication as they certainly cannot be for sealing, so can another material be used?
[Edited on 15/1/21 by 02GF74]
gremlin1234
posted on 15/1/21 at 09:58 AM Reply With Quote
would these help?
https://www.medical-world.co.uk/o/podiatry/chiropody/foot-care-products/corns/corn-padding-round-hapla-x-36/20396
or
https://www.medical-world.co.uk/p/podiatry/chiropody/foot-care-products/corns/fleecy-web-oval-corn-x-36/20401
McLannahan
posted on 15/1/21 at 10:58 AM Reply With Quote
Can any of the carb refurb companies assist?
https://classiccarbs.co.uk/
jimmyd
posted on 15/1/21 at 12:55 PM Reply With Quote
Thanks all, good shouts, am now currently talking to carb refurb company but failing that yes have selected suitable punches to order and make my own.
posted on 15/1/21 at 01:33 PM Reply With Quote
A slight flaw in the cunning plan.
I have some 1mm ish black felt, when compressed, and just had a go with the 8mm punch (I don't have a 12mm).
I wasn't able to punch through but no problems with 2mm gasket material.
An alternative may be to clamp the felt between 2 pieces of wood or aluminium and use an 8 mm drill, then roughly cut the felt and clamp between two 12mm washers and cut around with a sharp blade.
I'm sure it's doable just a matter of figuring out how.
jimmyd
posted on 15/1/21 at 06:31 PM Reply With Quote
Ah calling them felt seals rather than washers turns up results. £30 for 6!! Will look at the Locost version.
