Author: Subject: Sierra Front LH/NS Hub
Rallychris
posted on 17/11/22 at 05:01 PM Reply With Quote
I'm currently building up the front suspension of my RH 2B, but have a suspicion that the geometry of the front LH/NS/Passenger side hub casting is not quite right and it may have suffered a kerb strike in its original life!
Before I attack my new upper wishbone to make enough clearance to bring the camber angle into spec, does anyone have a spare front hub available to buy?
    Either a bare Sierra housing or a built up assembly (2wd).
    Alternatively if anyone has one they could lend me, if not for sale, to check if it solves the geometry issue that would also be very useful.
I'm located near Newbury, Berks so can either collect locally or pay for courier collection.
Robin Hood 2B Mazda Project Started March 2021
posted on 19/11/22 at 03:16 PM Reply With Quote
Can't help with a part.
Any ideas where the part you have is damaged/bent?
Cast iron part so it'd take quite a thump to bend it.
It could also result in a damaged or even cracked part.
