greggors84
posted on 14/2/05 at 08:44 PM |
Gear lever remote
I need a gear lever remote, like the one westfield do, and i think Tiger do a similar one now too.
Just want to move the lever back from the dash a bit.
Chris
The Magnificent 7!
flak monkey
posted on 14/2/05 at 08:58 PM |
If you have the facilities to make one then David Jenkins website has instructions on how to make one....
http://www.dwjenkins.plus.com/
Sera
http://www.motosera.com
macspeedy
posted on 14/2/05 at 09:13 PM |
you have u2u
greggors84
posted on 14/2/05 at 10:42 PM |
Replied to your U2U macspeedy.
Havent got access to a lathe so cant really fabricate my own.
Chris
The Magnificent 7!
niceperson709
posted on 15/2/05 at 06:39 AM |
Have a look at this picture I recon you could make one with a drill press angle grinder and the trusty mig
Best wishes
Iain
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
Dick Axtell
posted on 15/2/05 at 08:47 AM |
Remote g/c
Right NP709,
That's how I aim to do mine. Will use rose-type joint at base of gear lever, similar to your scheme.
So, how do you manage to select reverse?
With my box, you have to depress the gear lever, to achieve the necessary sideways movement to reach reverse.
I'll be interested to hear how you did it.
Dick
Ronin
posted on 15/2/05 at 10:21 PM |
I could be wrong but if memory serves me right I think it tells you how to make your own remote linkage in the Tiger book. Probably the only good
thing in it.
greggors84
posted on 15/2/05 at 11:05 PM |
Dick, there is a little bit of metal in the gearbox that stops the gearlever going straight into reverse, you push the gearlever down to go under
this. I understand this can be removed, meaning that you can put the gearlever straight into reverse without pushing it down. You will just to watch
out when you change gears.
Chris
The Magnificent 7!
Shogun969
posted on 16/2/05 at 09:43 PM |
Remote gear change
First Post , all you do is Knock out the rear blanking plate from the box and weld a bolt or something to the block of metal that is the reverse stop.
I have fitted a bleeper to the reverse light switch so if you accidently select reverse when at a standstill it lets you know.
macspeedy
posted on 17/2/05 at 11:13 AM |
the more full proof method is to remount the small piece of metal metioned above at the new gearlever position but that means you have to use the
westy type remote i have already made one of these (with no problems what so ever!) and will turn a few more in the next we while
