scutter
posted on 24/2/05 at 09:46 AM |
where to get compression spring?
Folks, I'm after a compression spring to fit to my Ron Campion(Luego) pedal box, Also the online build manual says to use a split bush on the
clutch pedal any ideas what there on about?
Cheers in advance Dan.
andrew.carwithen
posted on 24/2/05 at 04:06 PM |
Dan,
They're referring to the white nylon bush the spring is located on in your pic!
Its there to line the hole in the chassis member and so prevent chafing of the clutch cable.
I used a piece of nylon tube to do the same job.
I've heard of people using the spring from a sealant gun but I found it to be too short.
I bought a couple of springs at a kitcar show which I reckon will do.
HTH,
Andy.
scutter
posted on 24/2/05 at 08:45 PM |
Cheers Andy, looks like i'm off the the station workshops monday.
ATB Dan
