andyharding
posted on 14/3/05 at 09:56 AM |
Sierra downlink
I've managed to kill the rubber joint on mine while extending it so I'm gonna need a new one.
The 16mm solid shaft type.
Anyone got one laying around?
James
posted on 14/3/05 at 12:38 PM |
Luego (IIRC) sell replacement Polybush ones if that helps,
James
- Muhammad Ali
posted on 14/3/05 at 12:58 PM |
Which bit is knackered?
You can buy the rubber bit on its own, grind the rivet heads off and replace them with M8 bolts with nylocs.
andyharding
posted on 14/3/05 at 01:29 PM |
The little metal strips that connect the 2 rivits across the rubber are what I've bent. Do these come with a new rubber disc?
Digital camera batteries are on charge. Will try and post a pic later.
James
posted on 14/3/05 at 05:12 PM |
How the hell did you manage to bend them?
Can't you just bend them back? Then replace the rubber if necessary.
James
- Muhammad Ali
andyharding
posted on 14/3/05 at 06:25 PM |
I was trying to encourage the cut downlink into the (too small) extension tube!
I'm pretty sure they ain't gonna go back too!
[Edited on 14/3/05 by andyharding]
