Author: Subject: Vauxhall ignition
Darren.S
posted on 4/4/05 at 06:40 PM Reply With Quote
Vauxhall ignition
Has anyone got, or know where I can get hold of the ignition system off an early 8v vauxhall. I need the coil, ignition module, dizzy with the vacume advance on the side and the wires off the loom with the correct plugs on. It must be all off the same car though. I've changed my engine to a 2lt 16v redtop, and this is the last thing i've got to do to get it on the road, but i'm pulling my hair out trying to find anything. there seems to be no old vauxhalls in my neck of the woods. Any help would be gratefully recieved.
nige
posted on 4/4/05 at 07:43 PM Reply With Quote
ignition bits
sorry im no help .... im in the same boat
ive managed to source a dissy off ebay
you need the one with the plastic peg
i look every time i go near a scrappy
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
ned
posted on 4/4/05 at 08:04 PM Reply With Quote
you could try on migweb. I got lucky with a dizzy in a scrappy, but have since bought a full dta ecu and throttle body kit! Afraid someone already has dibs on the dizzy i still have..
there are second hand alpha 2d systems around for under a couple of hundred quid, it's just finding them..
Ned.
beware, I've got yellow skin
Darren.S
posted on 4/4/05 at 08:22 PM Reply With Quote
I've actually got all the parts I need, but the coil and ignition module are off one vauxhall and the dizzy (i've got 2) is off another and all though the wires and plugs all fit I get no spark. I went to my local vauxhall dealer and they told me that unless its all off the same car its not compatible because they made that many different systems all slightly different. I reckon they do it just to be a pain in the arse!
Marcus
posted on 4/4/05 at 08:29 PM Reply With Quote
You could try the Manta owners club. Decent chaps, always people braking 1.8s
Marcus
Marcus
Because kits are for girls!!
Darren.S
posted on 4/4/05 at 08:44 PM Reply With Quote
Don't spose you have the name of the website?
nige
posted on 4/4/05 at 09:04 PM Reply With Quote
ignition
http://www.mantaclub.org/
try this
James
posted on 5/4/05 at 01:00 PM Reply With Quote
What about using MegaJolt?
DIY ignition ECU.
HTH,
James
Stu16v
posted on 5/4/05 at 08:41 PM Reply With Quote
Originally posted by Darren.S
I've actually got all the parts I need, but the coil and ignition module are off one vauxhall and the dizzy (i've got 2) is off another and all though the wires and plugs all fit I get no spark. I went to my local vauxhall dealer and they told me that unless its all off the same car its not compatible because they made that many different systems all slightly different. I reckon they do it just to be a pain in the arse! [/quote
Darren, thats rubbish - as long as it is all Bosch stuff. When I ran my XE on an 8v dizzy (which itself was built from two dizzys, because I couldn't find a complete one with the right drive), the coil and amplifier actually came off a VW Polo! All the dizzy is is an electronic signal for the amplifier to 'work' the coil, and pretty much all of the Bosch stuff will work.
Darren.S
posted on 6/4/05 at 05:45 AM Reply With Quote
Any ideas why my set up won't work then?
I know all the parts work seperatly because I've had them tested. But when I wire it all up I can't get a spark.
Stu16v
posted on 6/4/05 at 08:01 PM Reply With Quote
How were all the separate parts tested?
Is it wired correctly?
nige
posted on 6/4/05 at 08:45 PM Reply With Quote
16v ignition
stu16v .... will this coil work ??????????
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=4540928406&ssPageName=STRK:MEWA:IT
