Author: Subject: Fireblade Alternator Cover
Mark18
posted on 4/5/05 at 11:05 AM Reply With Quote
I'm looking for a cover to suit a 1995 bike, I'm not sure which year bikes are compatible, but so long as the diagonal distance between the alternator mounting holes is 53mm it'll work. Thanks
Mark
"I don't know what I may seem to the world. But as to myself I seem to have been only like a boy playing on the seashore and diverting myself now and then finding a smoother pebble or a prettier shell than the ordinary, whilst the great ocean of truth lay all undiscovered before me." - Isaac Newton
hector
posted on 4/5/05 at 06:13 PM Reply With Quote
Hi
be sure of the model when you buy one as the early type are different to the later foxeye models, you can tell by the early ones were flat on the outside (with Honda cast in it, as they all have) but the later foxeye one have 3 radial gorooves in em and the alternator mounts ARE different diameters, only some bike breakers will sell you anything!
Also 95- was about when the foxeyes took over from the round headlamp models
cheers
Mark18
posted on 4/5/05 at 06:58 PM Reply With Quote
Yeah, I'm looking for the one without the grooves then, they all seem to fit onto the engine, so as long as the holes are 53mm apart then it should work.
Mark
andrew.carwithen
posted on 4/5/05 at 08:13 PM Reply With Quote
Have you tried looking on ebay?
'blade engine covers and the like crop up pretty frequently.
Andy.
hector
posted on 4/5/05 at 09:10 PM Reply With Quote
the ones without the grooves is the early ones( RRN to RRP models), they have two round headlamps, 893cc engine
cheers
andrew.carwithen
posted on 5/5/05 at 08:10 PM Reply With Quote
You could also try www.firebladeshop.co.uk
Advertise them for £20.
Andy.
