Xflow Driver
posted on 11/5/05 at 04:57 PM |
Throttle Cable
http://www.beepworld.de/memberdateien/members18/claudiasbilder/carbend1a.jpg
http://www.beepworld.de/memberdateien/members18/claudiasbilder/carbenda.jpg
http://www.beepworld.de/memberdateien/members18/claudiasbilder/pedalenda.jpg
Can any one help identify this ford throttle cable, the lead barrel is from
the carb end and has snapped off, the pedal end fixes in place with a
circlip. It is a little over a meter long.
posted on 11/5/05 at 05:55 PM |
Transit ?
posted on 11/5/05 at 07:37 PM |
If the nipple was from the pedal end it would look like a Mk1 1300 Escort cable. The nylon end used to fit on a ball at the carb end and a round
spring clip used to snap over it to hold it on. I had one years ago and lost the clip off it and had a right job finding another clip
theconrodkid
posted on 11/5/05 at 07:44 PM |
wasnt the mk1 very short,the mk2 went over the engine and was longer?check if its got a part no,i made my own with bits from a kit carried by AA/RAC
patrols
who cares who wins
pass the pork pies
posted on 11/5/05 at 07:50 PM |
Might have been, it was years ago and was most likely made from several other cars.
Xflow Driver
posted on 11/5/05 at 08:05 PM |
The cable has Ford and 92060 on it. My local Ford handler thinks that this has the part No 6605418 but could not tell me any more as it is
obsolete.
[Edited on 12/5/05 by Xflow Driver]
Schrodinger
posted on 11/5/05 at 09:08 PM |
Could you use a solderless nipple on the end?
Keith
Suffolk
MikeR
posted on 11/5/05 at 10:03 PM |
where do you get solder or solderless nipples from????
clbarclay
posted on 11/5/05 at 10:06 PM |
patrols
The mk2 1300 cable is definatively short. The carb is on the off side. You would need a pinto (RS 2000) with the carb on the near side to have the
cable going over the engine.
Schrodinger
posted on 12/5/05 at 11:41 AM |
Mike wrote
<where do you get solder or solderless nipples from????>
Cycle shop
Keith
Suffolk
Xflow Driver
posted on 12/5/05 at 04:31 PM |
I have no idea what a solderless nipple is, can you explain?
Schrodinger
posted on 13/5/05 at 11:25 AM |
It looks similar to the nipple that broke off the cable only where the cable passes through and is soldered on the picture the solderless nipple has
just a hole and a grub screw in the end to clamp the cable in place.
I think I may have one in my tool chest at home and will see if I can find it and post a picture.
Keith
Suffolk
Xflow Driver
posted on 13/5/05 at 07:49 PM |
I think I know what you mean, I went to my local motor bike shop and they have a set to do temp repairs to cables but they were very insistant that it
was only to get you home in an emergency.
