ASH3
posted on 2/6/05 at 06:16 PM |
Mkll Cortina
Desperate for a release bearing
carrier (old kit car or what! dont ask..)
flak monkey
posted on 2/6/05 at 06:50 PM |
Give tiger racing a call. My dad said that they had a couple of Mk2 'tinas there a few weeks ago (not sure if he was right or not though). They
may be able to help, or at least point you in the right direction if they cant.
Sera
http://www.motosera.com
posted on 2/6/05 at 07:27 PM |
Is it the type with the 2 bent wire clips and the D shape spacer ?
ASH3
posted on 2/6/05 at 07:41 PM |
Would not say clips that retain it
to the lever but two turned over
peices of the retainer one of which
has broke off. Dont recall the spacer beind D shape either.
posted on 3/6/05 at 06:34 AM |
The type with the D spacer was the early Cortina type that came originally from the Anglia and is fitted to all Lotus Cortina models -- these went
out of supply but repro ones are now made.
BUT that dosen't help you because it won't fite your later type bellhousing (I know I tried it the other way round).
Your best chance is the finding one through some of theowners clubs or if you can't converting to a Saab co-axial slave cylinder,
