ady8077
| posted on 25/6/05 at 09:29 PM |
Rear fill pinto cam cover
Hi anyone got one, or no where to get one from?
Adrian
greggors84
| posted on 25/6/05 at 09:40 PM |
Burton do one, its a bit pricey though, not to hard to make your own if you can weld.
Chris
The Magnificent 7!
mookaloid
| posted on 25/6/05 at 10:27 PM |
I think tiger do one too
I actually ended up making my own after trying to buy one.
In the end it was easy enough to make.
I cut one up and welded the filler neck off one onto the other.
Mark
andrew.carwithen
| posted on 26/6/05 at 08:43 AM |
Before I decided to switch to a bike engine, I modified my own pinto rocker cover.
I used a section from a Sierra 2 into 1 exhaust downpipe and then sleeved the original filler neck into it (perfect fit) to enable oil filler cap to
fit.
After welding, used 'Quicksteel' filler to smooth off and then painted.
(See pics in my archive).
Mark Allanson
| posted on 26/6/05 at 10:43 AM |
Where did you get that idea?
Ian Pearson
| posted on 26/6/05 at 11:21 AM |
I've done the same, got the idea from "TOL".
andrew.carwithen
| posted on 26/6/05 at 05:14 PM |
Yep, you're right, Mark.
Did get the tip about using a section of the 2 into 1 downpipe from you. (Did a search under 'rocker' and found it!)
Andy.
ady8077
| posted on 26/6/05 at 05:24 PM |
I did alter mine, cut the filler spout off and used a cvh type cap, but it leaks
I also fitted a breather pipe to the rear, but that chucks all the oil out
But i like the way Mark & Mark have done it, might try again
Adrian
