Author: Subject: Dellorto Twin DHLA40 Throttle Linkage
Stuart Walker
posted on 21/7/05 at 02:00 PM Reply With Quote
As per the title, need a twin 40 linkage for my DHLA's, trying to avoid paying £50 for a new one...
Stu
stevebubs
posted on 21/7/05 at 05:02 PM Reply With Quote
Stu
I'll have a nosy around in the garage a little later - may actually have one of these lying around.
Stephen
stevebubs
posted on 21/7/05 at 05:08 PM Reply With Quote
Are you only after this part?
If so, do you want to swap it for the DGV?
Stuart Walker
posted on 21/7/05 at 06:14 PM Reply With Quote
Is that definately for two, or just a single one?
If its definately for two then the swap sounds fine.
Stu
stevebubs
posted on 21/7/05 at 06:30 PM Reply With Quote
It's what I took off my twin 40s when I replaced it with a lowline one.
It's missing
the rod(s) that goes down to the actual bodies
The upright plate that the throttle cable comes through.
Both these should be easily fabricated
stevebubs
posted on 21/7/05 at 06:34 PM Reply With Quote
BTW If you can wait until around 18/19 Aug then I should be in Doncaster for a few days - can meet up halfway between Donny and Stokesley and swap then if you want
