welderman
| posted on 27/7/05 at 04:37 PM |
Speedo sensor for blade engine
Speedo sensor for Fireblade engine, the one that bolts to sprocket cover.
1996 engine.
mad-butcher
| posted on 27/7/05 at 05:39 PM |
you mean this,what's it worth inc p & p
welderman
| posted on 27/7/05 at 05:49 PM |
U2U sent
Avoneer
| posted on 27/7/05 at 06:32 PM |
If you're using the blade clocks, any hall effect sensor will work as long as it gives a 5v pulsed output.
Pat...
welderman
| posted on 27/7/05 at 06:42 PM |
That sounds a bit complicated, bit to much for me i think. Unless you can breifly explain, please.
