jos
| posted on 3/8/05 at 02:56 PM |
Indicators
Does anyone have a set of front indicators that are either mounted on stalks or on those funky little brackets to mount under the headlights ala
cateringvan/westie styleeee that I could use to pass SVA.
Ive got some little indicators which will be installed post SVA but their post SVA location wont give me an SVA pass initially
| posted on 3/8/05 at 03:08 PM |
Can you not mount them on longer stalks, or is it the actual location of them which is the problem?
jos
| posted on 4/8/05 at 07:54 AM |
The ones Ive got for post SVA are similar in mounting to side repeaters i.e. double sided sticky tape but are a lot bigger than side repeaters. They
dont have any stalks at all at the moment.
| posted on 4/8/05 at 08:19 AM |
i have a spare pair, do you want me to measure the stalks?!
jos
| posted on 5/8/05 at 02:07 PM |
No thanks Joel I think Ive sourced some relatively cheaply so if someone needs some in the future to get through SVA let me know, assuming they do the
job.
If they not suitable theyll go up for sale and I will ask you to measure Joel.
