Author: Subject: sierra drive shafts
chris.russell
posted on 8/8/05 at 08:59 AM Reply With Quote
sierra drive shafts
Anyone got a pair of unwanted sierra drive shafts in need of a new home and are in the Oxfordshire area?
Must be for drum brakes mind (unlike the current pair I have sitting painted at home!.:mad
Mines a pint
ChrisW
posted on 8/8/05 at 12:47 PM Reply With Quote
I've got a complete set of *disc* shafts including the hubs, bearings, discs, calipers - ie everything you need to convert to discs.
Any use?
Chris
chris.russell
posted on 8/8/05 at 02:00 PM Reply With Quote
I did consider it but i would also need different uprights from mk. Would the disc drive shafts bolt straight onto my 3.62 diff?
Mines a pint
ChrisW
posted on 8/8/05 at 04:00 PM Reply With Quote
As long as it's a lobro type diff I expect they would fit. I also expect that you could undo the circlips and fit the disc type shafts to the push in type joints.
Both of these ideas are theory only - I havn't tried either myself!
Chris
chris.russell
posted on 8/8/05 at 04:13 PM Reply With Quote
i'm off work tomorrw so i will check out the local scrap yard and see what i find, if all else fails i will be in touch!
Mines a pint
ChrisW
posted on 10/8/05 at 09:50 AM Reply With Quote
Well I've got two other enquiries so make your mind up quick!
FYI I'm after £50 for the lot - based on the fact that the calipers are worth £30-35 trade in!
Chris
