Benzine
| posted on 16/8/05 at 04:24 PM |
Alternator arm
I'm using a bedford rascal alternator on a pinto. Using the standard alternator arm I have (from a DOHC 2.0i sierra) it won't reach so I
need one that's about 20cm long. Does anyone have one lying around or know which model ford has one this length so I can order one?
| posted on 16/8/05 at 04:55 PM |
Just get a bit of steel strip and make one to the right length. You can make a slot by drilling a row oh holes and filing through. That way
you'll get exactly what you need.
HTH
Nick
Benzine
| posted on 16/8/05 at 04:58 PM |
This alternator arm has a bend in it which I'd like to have. I'd have no way of bending steel that thick The lack of steel is also a
problem Thanks anyway though, if I can't find one then I'll get my uncle to knock one up for me
indykid
| posted on 16/8/05 at 05:01 PM |
if you weren't in leicester, i'd give you a perfectly shaped bit of steel to do the job, that fits onto the thermostat housing top bolt.
if you go to halfords, you may be able to persuade them to give you one of the brackets from the end of their battery plinth, that has the cable and
bits hanging on it. it has the perfect offset to sit right up against the locking bolt lug. they should have some kicking about, but you'll have
to put your own slot in it.
if not, have you not got a welder? couldn't you extend the solid piece on that one?
hth
tom
big_wasa
| posted on 16/8/05 at 05:54 PM |
Mines of a Renault 5 arm...You could get one from the scrappie for a quid or so, or a nice shiney one from
ebay
Benzine
| posted on 16/8/05 at 08:16 PM |
Hehe, by coincidence, I did actually get a bracket from a Renault 5 the other week at the scrappies but it doesn't fit, nearly does but not
quite there
| posted on 16/8/05 at 10:52 PM |
Put some more washers behind the bolt or make a spacer from some tube.
