Avoneer
| posted on 24/10/05 at 07:26 PM |
Standard Mk2 Escort Wheel Studs
Anyone got any rusting away in the back of their garage?
Thanks,
Pat...
Aboardman
| posted on 24/10/05 at 07:32 PM |
have some cortina wheel studs are they the same?
regards
Andrew
Avoneer
| posted on 24/10/05 at 07:40 PM |
Not sure, think the Cortina ones are UNF???
Pat...
Aboardman
| posted on 24/10/05 at 07:49 PM |
think that they are M12x1.5x63mm as
i had to get longer studs as i fitted 17" wheels and the standard studs where too short, so i have the extra long ones and the standard ones
these may be unf
regards
Andrew
big_wasa
| posted on 24/10/05 at 07:58 PM |
As you say Pat the new studs are all one size. But I pressed a set into the cortina uprights ,fitted fine ...
Will be doing the same with the capri axle so just been out to the garage and pressed these out if you want them ?
would of offered to turn yours down but i dont think you should mess with them myself...
Avoneer
| posted on 24/10/05 at 08:00 PM |
Hi Mate,
Can you mesure the length of the splined shoulder bit pretty please?
Pat...
Avoneer
| posted on 24/10/05 at 08:01 PM |
Actually, don't bother..
I'll take them all!
How much do you want etc.....
Pat
bob
| posted on 24/10/05 at 08:02 PM |
Pat
I'll try and check the thread size of these bad boys and get back as soon as i can.
Avoneer
| posted on 24/10/05 at 08:10 PM |
Hi Bob,
Cheers, but the shoulder looks too long for my application (don't ask).
Cheers anyway - you're always good for bits!
Pat...
big_wasa
| posted on 24/10/05 at 08:12 PM |
Hi Pat actual splines are 6mm long then a 2mm taper to the thread, whole stud is about 36mm.
U2 me your address and ill try and get them out in a jiffy bag tommorow.....
regards warren
Avoneer
| posted on 24/10/05 at 09:14 PM |
Hi Big W,
They are metric aren't they - pressume they are being from a Capri.
Address has been U2U's,
Cheers mate,
Pat...
big_wasa
| posted on 24/10/05 at 09:22 PM |
yeh metric..
Your name for the the top of the jify bag would be good Pat .
They arnt worth anything to me, so free if the postage isnt stupid...
Avoneer
| posted on 24/10/05 at 09:37 PM |
Hi Big W (Could be a shop name that!)
Pat W, Avoneer, whatever you like!
Pat
