tim windmill
posted on 2/11/05 at 10:28 PM |
Carbon Fibre Panel
hi,
thinking about how to do the interior of car, i like the look of the carbon fibre sheet does anyone know where i can get hold of some sheet for the
panels?
Thanks Tom
Triton
posted on 2/11/05 at 10:35 PM |
Depends what sizes you need
www.tritonraceseats.com
www.hairyhedgehog.com
Oliver Jetson
posted on 2/11/05 at 10:50 PM |
Fluke-Motorsport sell carbon fiber sheets in varying thicknesses and plys.
Interior panels only need to be between 1 and 2 mm of thickness, bonded and riveted on.
Retails at something upwards of £100 per 1000mm by 500mm i think.
Oli
bimbleuk
posted on 3/11/05 at 08:41 AM |
or do a search on carbon effect ABS sheet if you don't have to use real Carbon fibre weave.
http://www.esp-plastics.co.uk/acatalog/molding_plastic_sheeting.html
Howlor
posted on 3/11/05 at 08:46 AM |
I used this guy called Matt. It was £75 for a 1000x500 sheet and superb quality.
Mmnjs@aol.com
Russ-Turner
posted on 3/11/05 at 08:55 AM |
Bit O/T I know but just out of interest how easy is this stuff to cut? Is it a masking tape and hacksaw jobbie, can you use a jigsaw with a fine blade
or does it splinter?
ayoungman
posted on 3/11/05 at 11:40 AM |
A decent pair of tinsnips cuts the 1mm sheet very nicely.
"just like that !"
tiffshaw
posted on 3/11/05 at 05:13 PM |
Hi
For cutting carbon fibre the best things to use are grit edged hacksaw blades available from screwfix direct.
This is what I was supplied with on a carbon fibre course.
Chris.
RazMan
posted on 3/11/05 at 10:40 PM |
B&Q sell the hacksaw blades in the same style - cuts like butter.
Raz
