lsdweb
| posted on 18/12/05 at 10:49 AM |
Wheels - 95mm PCD - no offset!
Hi All
I need a set of wheels and tyres that have a 95mm PCD and little or no offset. Condition immaterial!
These are to fit on my single seater so that I can get it to fit on my trailer! They will only be used for when the car is on the trailer so even if
the tyres are asolutely wrecked it doesn't matter.
Does anybody know what wheels would suit? I've read somewhere that Maestro/Montego are this size?
Regards
Wyn
rsk289locost
| posted on 18/12/05 at 11:03 AM |
Might sound silly but make some from 1" thick plywood discs. F1 teams have used billet alloy ones and if they are "true" you can
utilise them for measurements whilst setting up the suspension.
lsdweb
| posted on 18/12/05 at 01:13 PM |
I'd thought of that but I need to be able to move the car around, sometimes in a grass paddock and 1" ply wheels wil sink pretty quick!
| posted on 18/12/05 at 02:34 PM |
Most single seaters used the small Triumph PCD 3.75" 95.25mm This was also used on the Marina/Ital because it used a Triumph axle.
K engined Metros/Rover 100 have it and the MGF/MGTF also used it.
lsdweb
| posted on 18/12/05 at 05:45 PM |
Thanks BritishTrident
My choice is quite wide - I'll head to the breakers tomorrow!
Regards
Wyn
CGILL
| posted on 19/12/05 at 06:01 AM |
Triumph Toledo/1300/1500 wheels will have a bigger inset than herald/spitfire wheels, the marina will stick further out than spitfire etc.
