Author: Subject: Ford prop shaft needed
rusty
posted on 19/12/05 at 01:46 PM Reply With Quote
Hello
We are looking for a ford prop shaft to fit a 5 speed type 9 with a 1" rather that 3/4" spline.
It needs to be the type that go's straight from the spline to the UJ not the type with a big rubber coupling.
muzchap
posted on 19/12/05 at 01:50 PM Reply With Quote
You should ring Bailey Morris, they make excellent prop-shaft's made to measure.
140 quid delivered, and worth every penny - completely balanced and weighted.
Would you risk something 'cheap' spinning at that speed next to ya A$$? I know I wouldn't :p
Click Here
Murray
posted on 19/12/05 at 02:06 PM Reply With Quote
Transit one.
Tranny don't have the rubber donut in them.
rusty
posted on 19/12/05 at 04:05 PM Reply With Quote
mmmm
Might look into that
DaveFJ
posted on 19/12/05 at 04:28 PM Reply With Quote
very early sierras had no 'Donut'
Dave
lsdweb
posted on 19/12/05 at 05:14 PM Reply With Quote
Hi Rusty
What diff and how long?
Wyn
wilkingj
posted on 19/12/05 at 07:29 PM Reply With Quote
If you get BM to do it, they change the UJ's to circlipped ones as the Ford ones are staked in.
Which means its a pain to change the U/j's later should you need to. BM made an excellent job of both my props. (Son's Plastic Pig / Jago needed a new prop)
Also they are only at St Neots, / Eaton Socon. ie Local.
Good job and worth the noney.
Best Regards
Geoff
http://www.v8viento.co.uk
rusty
posted on 20/12/05 at 02:35 PM Reply With Quote
Not sure of the length but the flange on the diff is vauxhall viva. I can messure the length later.
The thing is I have the old shaft but it is to laong and has the wrong spline as we changed the gearbox from 4 speed to a 5 speed.
