Author: Subject: RV8 Flywheel
darrens
posted on 3/1/06 at 08:19 PM Reply With Quote
RV8 Flywheel
as above if anyone has one around yorkshire area, pref SD1 varient
Darren
wilkingj
posted on 5/1/06 at 08:42 PM Reply With Quote
If you are using a LT77 box, then you must get a flywheel for a P6 or SD1, ie a 9.5" clutch, and not the 10.5" for the Rangerovers etc. cos the 10.5 clutch wont fit in the bell housing... or so I am told.
also they are lighter than the 10" flywheel
Of course you can use a Landy / rangey flywheel, if you get it re-drilled for a 9.5! clutch.
Best Regards
Geoff
http://www.v8viento.co.uk
darrens
posted on 5/1/06 at 11:33 PM Reply With Quote
I, that's what I'm after, just can't bleedin find one.
Darren
TL
posted on 6/1/06 at 12:24 AM Reply With Quote
Any use?
ebay item 4601689018
Terry
