Avoneer
posted on 3/1/06 at 09:53 PM |
9/16 Tap and appropriate drill bit
Anyone got a 9/16th tap and appropriate drill bit I can borrow for one hole in my aluminium fuel tank?
Of course I will pay the postage if anyone is willing to post me one (I'll send a self addressed Jiffy bag).
Pat...
lsdweb
posted on 3/1/06 at 10:12 PM |
Pat
I should have a 9/16" tap and I can put it in the box with the calipers if you want?
Wyn
Avoneer
posted on 3/1/06 at 10:23 PM |
That would be great Wyn and I'll sned it back with the gear display if that's ok???
Do you know what size drill bit - I get it to just over 14mm so hopefully 14mm should be fine in Ali ???
Pat...
lsdweb
posted on 3/1/06 at 10:26 PM |
No problems. I'll check the drill bit chart and let you know the size - I can't do it now as SWMBO is pi**ed off with me as I've
been in the garage selling my Hewland gearbox, and on Tinternet all evening!
Avoneer
posted on 3/1/06 at 10:34 PM |
No probs.
Get in the kitchen, do the washing up and make her a brew.
Pat
lsdweb
posted on 4/1/06 at 08:06 AM |
Pat
I've just searched high and low for my 9/16" tap but can't find it anywhere - sorry!
Recommended tapping drill sizes are available at:
http://www.brook-tech.fsnet.co.uk/reference.htm
Regards
Wyn
gazza285
posted on 4/1/06 at 11:21 AM |
I've got a few 9/16" taps, but what thread form do you want?
907
posted on 5/1/06 at 12:56 AM |
Seems a funny size.
It's not 1/4 bsp is it?
Paul G
Avoneer
posted on 6/1/06 at 09:10 PM |
Think Automotive told me my breather valve is 9/16 UNF.
The nut for the same also said 6JIC.
Anyone any clearer?
Pat...
Avoneer
posted on 6/1/06 at 09:20 PM |
Just found out that 9/16 and 6JIC are the same.
Get 12.9mm for hole size.
1/2" drill bit in ali ok?
Not sure of the thread pitch - can any one help me out there?
Pat...
lsdweb
posted on 6/1/06 at 09:30 PM |
Pat
You have U2U - but not about this thread!
Regards
Wyn
gazza285
posted on 6/1/06 at 09:55 PM |
1/2" in ally will be fine. I'll dig you out a tap if you want it. 9/16UNF is 18tpi.
Avoneer
posted on 6/1/06 at 10:37 PM |
Mr Gazza285,
Where abouts in fuddershield are you?
I'm only in Dewsburger.
Pat...
gazza285
posted on 6/1/06 at 11:25 PM |
As far away from you as I can get.
Also known as Longwood.
I did used to work on Bradford Road in Dewsbury though.
Avoneer
posted on 6/1/06 at 11:26 PM |
Any chance of meeting me at the big B&Q near the stadium some time?
Pat ;-)
gazza285
posted on 6/1/06 at 11:55 PM |
All possibility.
Avoneer
posted on 7/1/06 at 12:14 AM |
Just thought - I should stop being a lazy reformed mancunian.
If I drill my 1/2" hole through my ali tank, can I pop over to yours for you to run your tap through mi 'ole n all that???
Pat...
gazza285
posted on 7/1/06 at 12:36 AM |
It would save you two trips. Let me make sure I've got a tap first, but I'm 99% sure.
gazza285
posted on 7/1/06 at 02:32 PM |
I've got 9/16 BSF which is 16tpi, I've got 9/16 UNEF which is 24tpi and a 9/16 UNC. The one I can't find is the 9/16 UNF, sorry.
Avoneer
posted on 9/1/06 at 06:15 PM |
Anyone???
Still after that elusive tap!
Pat...
Avoneer
posted on 12/1/06 at 10:58 PM |
Still looking.........
