| posted on 8/1/06 at 12:15 PM |
Stainless Steel
Does anyone have an offcut of Stainless Steel plate?
We're looking for a piece, roughly 150mm x 150mm x 6mm thick and not having much joy at present.
Guinness
| posted on 8/1/06 at 12:20 PM |
I'll have a look at work in the morning, but I doubt it, we don't usually work with much more than 3mm.
Have you tried Metalsupermarket? They will try to help, but they're not cheap.
If you don't mind me asking, what's the application, that needs to be so thick?
Mike
jambojeef
| posted on 8/1/06 at 12:21 PM |
I might have - I'll have a check in a minute after I get out to the garage
Geoff
andyw7de
| posted on 8/1/06 at 12:22 PM |
I will have some at work and could probably cut you a bit on monday and post it to you if you cant get anything closer, does it have to be 6mm or
would 5mm do, depends on what cuttings are lying about,
let me know
cheers
| posted on 8/1/06 at 04:07 PM |
Thanks fellas. It's going to be machined into a doughnut for bolting our new silencer to. It Doesn't necessarily have to be 6mm but would
be preferable.
If someone can confirm they've got a piece, I'll drop a U2U with my address. Cheers.
welderman
| posted on 8/1/06 at 04:58 PM |
I will look in the morning.
Thank's, Joe
I don't stalk people
