Flat Pack
posted on 14/1/06 at 05:59 PM |
Sierra CV joints
I'm looking for the tri-lobe parts of 2 Sierra push in CV joints with 25 internal splines.
If anyone else is trying to make up hybrid driveshafts with lobro joints on one end and tripode on the other, I'd swap the innards of your inner
tripode joints for some lobro ones and backplates if you like.
I'd also consider complete outer joints ![](/images//smilies/smile.gif)
RichieC
posted on 14/1/06 at 06:31 PM |
Hello again mate. Not sure if I said, but I bought a set of shafts from a scorpio from eBay for a fiver. Then I had the guy take a hacksaw to them
and just send me about 4" of shaft and the joint, worked out less than 9 quid all in.
I never even considered keeping the tripode bits, they went straight in the bin - doh you could have had them for nowt.
Good luck, Rich
Flat Pack
posted on 14/1/06 at 09:35 PM |
Yeah I'm keeping an eye on Ebay too Problem is I don't want to end up with yet another set I can't use and most people
don't fancy butchering the joints to check for me
I've looked at getting the tripode bit new, but they're far too expensive... I'm hoping the best bet will be to find someone trying
to put an LSD in a drum braked car and do a swap.
