jacko
posted on 16/1/06 at 09:15 PM |
zx9r carb part
Hi All - I am using ZX9R carbs and the small pipe that the throttle cable goes through is missing has any one got one going spare? Much appreciated
for beer tokens.Thanks Graham [Jacko]
stevec
| posted on 16/1/06 at 09:37 PM |
Have you got a pic of the area on the carbs you mean, I have a set of ZX6 ones it may be the same trotter attachment.
Steve.
Mad Dave
| posted on 16/1/06 at 09:39 PM |
Which bit do you mean?
[img][/img]
jacko
| posted on 16/1/06 at 09:47 PM |
Hi it,s not on the picture Dave it may be part of the throttle cable it,s a bent metal pipe that the cable go,s through Graham
Dave it go,s on to part no 92009a if this helps
[Edited on 16/1/06 by jacko]
stevec
| posted on 16/1/06 at 09:50 PM |
I reckon I have one I will go and look in garage.
stevec
| posted on 16/1/06 at 09:57 PM |
Have a look in my photo archive under Trotter bracket, Is that it?
Steve.
jacko
| posted on 16/1/06 at 10:14 PM |
Hi Steve no thats not it the bit i want is on the cable that go,s in that bracket its a bent pipe 90%
Graham
MkIndy7
| posted on 16/1/06 at 10:19 PM |
I'm guessing it looks like one like they have on some Push bike brakes, another source of them maybe?
Think it might be the newer V-brake type setup where the cable pulls from 1 end rather than the middle where i've seen what I imagine it as.
jolson
| posted on 16/1/06 at 10:50 PM |
If a V-brake noodle (yes that's what they're called) will work, then send me a U2U and I'll get you one from work.
What sort of angle should the noodle be bent thru? They are usually around 90 deg, or 135 deg, or I can get a flexible one. Should take a 1.6mm
brake cable
John
MkIndy7
| posted on 16/1/06 at 11:10 PM |
Can't be arsed trying to figure out how to display a pic.
http://uk.search.yahoo.com/search/images?p=V+brake+noodle&ei=UTF-8&fr=FP-tab-img-t&fl=0&x=wrt
That link should display some piccys of the V-brake part, if its anything like that?
Mad Dave
| posted on 17/1/06 at 08:42 AM |
You mean the throttle cable ends like these (54012)
Image deleted by owner
I'll have a look to see if I have one, if so I'll U2UU
[Edited on 17/1/06 by Mad Dave]
jacko
| posted on 17/1/06 at 05:29 PM |
Hi Dave and all - Thanks for all the help in identifying the part Im after. I understand I can get one from a pushbike shop. So I will get one locally
now. All the best Graham
