Author: Subject: WANTED: stainless grill mesh
Humbug
posted on 22/1/06 at 10:08 AM Reply With Quote
Anyone got an offcut big enough for a grill?
Simon
MikeR
posted on 22/1/06 at 10:30 AM Reply With Quote
Try looking inside your wifes oven
piddy
posted on 22/1/06 at 10:54 AM Reply With Quote
B & Q.
Humbug
posted on 22/1/06 at 11:23 AM Reply With Quote
Looked in there, but don't fancy putting grease-covered metal on the front of my car!
Also, I am really looking for mesh, rather than the grill structure itself
graememk
posted on 22/1/06 at 11:44 AM Reply With Quote
our b&q have then bbq kits that build your self for £10, doubt they would make a good grill though.
tiffshaw
posted on 22/1/06 at 11:45 AM Reply With Quote
Hi
I have some mesh that we were planning to sell on ebay for about £30 a sheet to the boy racers. As you're on here we can do it for £20 plus postage.
Its high quality stainless woven mesh cut on the diamond and should be big enough for a seven nose cone. We have two sorts, highly polished stainless and black powder coated stainless.
Chris
Humbug
posted on 22/1/06 at 11:55 AM Reply With Quote
Originally posted by tiffshaw
Hi
Chris
Hi Chris - thanks for that. I have seen stainless woven grill stuff with about 10mm gap for under £20 in Halfrauds boy racer section. I was just looking to see if I could find anything a) cheaper and b) with a slightly smaller gap, to avoid major stone damage to the rad.
Anyone tried either of these?:
http://www.juststainless.co.uk/index2.htm
http://www.wovenwire.co.uk/
RichieC
posted on 22/1/06 at 11:57 AM Reply With Quote
B&Q or local diy shop sell ornamental mesh in a variety of finishes and patterns for about £5 a sheet big enough to do the nose
Rgds
Rich
Donners90
posted on 22/1/06 at 04:09 PM Reply With Quote
I've got some of the Woven Wire mesh
Hi Simon,
I bought some 10mm square woven mesh from wovenwire.co.uk. Very helpful and good service, however postage was quite expensive as they pack it between thin MDF.
If you change your mind about the size of the holes, I have some left if its of any use. I have attached a piccy with dimensions of the piece. I was hoping to get about £20 for what's left. I live in Brentwood so could meet Lakeside/Bluewater to save you postage.
I'm away for two weeks as of Monday, but can meet after 3rd Feb if you want it.
Let me know if it's any good to you.
posted on 22/1/06 at 09:29 PM Reply With Quote
The stuff in B&Q is expanded mesh. the nice stuff is voen.
if you a re still struggling, I will dig out info where I got some - mesh hole size from microscopic to quite big in a variety of metals.
bear in mind they have a minimum order quantity so may not get the result you want.
Humbug
posted on 24/1/06 at 10:56 AM Reply With Quote
Yes, if you could find the contact, I would be grateful
wilkingj
posted on 25/1/06 at 08:05 PM Reply With Quote
I got mine from this chap. Spoke to him on the phone, he will cut to size just for you.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=7553074779&ssPageName=ADME:B:EOIBSA:UK:11
Costs more if you have the mesh cut so you have a diagonal square, as it uses a larger bit to start with.
Very helpful, and quick. no problems with my purchase. He does stainless tubes and sheets as well.. cut to size if you want.
Contact him FIRST... they he will put it on ebay for you to buy so you can pay via paypal etc.
Cant fault him.
Best Regards
Geoff
http://www.v8viento.co.uk
ppuxley
posted on 29/3/06 at 10:25 AM Reply With Quote
Wanted :Woven wire mesh
Anyone still got some off-cuts of stainless woven wire mesh? Looking for 420mmx200mm (diamond arrangement) something around 10mm opening 1.5mm crimped wire .
Patrick
Humbug
posted on 29/3/06 at 09:08 PM Reply With Quote
Patrick
I've got some left after doing my grill: http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2006-02-17%204%20ST%20nose%20cone%20refitted.jpg
I've emailed you with more details
