907
| posted on 7/2/06 at 07:30 PM |
A Pair of Gears please.
Hi All,
I'm after a matching pair of gears or cogs to make a swager.
They need to be between 1 1/2" (40mm) and 2" (52mm) in diameter.
The number of teeth doesn't matter as they will only be driven by hand,
but they would be better if they were straight cut.
The important thing is that they are the same size.
The pic shows the sort of thing I'm after.
Top one is a feed gear off a Harrison lathe.
Bottom shows the gears on the end of my 3' rolls. (I'd prefer to keep them on the rolls)
Beer tokens or payment in kind await.
Anyone got any laying about?
Or know where I could buy a pair new?
Many thanks
Paul G
| posted on 7/2/06 at 07:33 PM |
Paul , similar gears come up on ebay pretty often for Myford lathes for not a lot of money.
omega 24 v6
| posted on 7/2/06 at 07:48 PM |
What about the gears from 2 old starter motors. You'd need to make up a shaft to hold them but it wouldn't be that hard surely.
907
| posted on 7/2/06 at 07:55 PM |
Hi Rusty,
trouble is they tend to be odd ones or sets, i.e. 20t 25t 30t etc.
I need two the same, but I will keep an eye on ebay.
Thanks mate
Paul G
ps Haven't forgot your go with the Tig
907
| posted on 7/2/06 at 08:10 PM |
Don't think they would be big enough m8
Here's a pic of a swager to give an idea of what I would like to make.
(missed this last night on ebay, by £1 )
Paul G
| posted on 7/2/06 at 08:12 PM |
I've got a pair of Myford gears with 21 teeth but it might be worth checking out
WWW.rdgtools.co.uk or look under Myford on ebay , they stock gears from about a fiver each
907
| posted on 7/2/06 at 08:19 PM |
What's the diameter of the 21t's
i.e. centres when meshed together?
Paul G
| posted on 7/2/06 at 08:33 PM |
Paul , with gears meshed centre to centre is approx 27mm overall dia approx 29mm . I have one 32 teeth gear that is approx 54mm dia bore size approx
16mm gears have keyway . Haven't for got tig lesson.
gary gsx
| posted on 7/2/06 at 09:07 PM |
ill have a look at work tommorrow i think i have a few gears from power take of units
907
| posted on 7/2/06 at 09:41 PM |
cheers Gary
Paul G
907
| posted on 7/2/06 at 09:53 PM |
Too small and too big I'm afraid Rusty.
I'll have a look on that web site.
I wanted to make the shafts from 1 1/2" and the tools from 2" HT bar. ('cause I know where I can get some)
Then I can make them longer. (ribs in sheet?)
Thanks a lot anyway.
Paul G
Nick Skidmore
| posted on 8/2/06 at 11:49 AM |
HPC in Lancashire somewhere have a book full of gears of all possible sorts.
I used them to repair a lathe some years back and they were spot on.
Hinchcliffe Precision Components is the full name
timf
| posted on 8/2/06 at 12:20 PM |
you could borrow my swadger for a while if you wanted paul, I'm not using it at present pluss it has several other wheels as well as
swadge/beed wheels.
Tim
Performs burring,edging,elbowing,flanging,flattening & turning.
Adjustable roll pressure applied by means of a top mounted hand crank. Can be used in both foward & reverse. The long throat makes this unit
highly versatile. Fast , smooth & precise operation. Includes table clamp.Includes 6 interchangeable rolls.
Cutting Capacity - 0.8mm
Distance between Centre Shafts - 2"
Throat - 7"
[Edited on 8/2/06 by timf]
gary gsx
| posted on 8/2/06 at 07:59 PM |
Paul
A a good look around stores today and the pto units are bol**ed so ill keep me eyes open for you
| posted on 8/2/06 at 08:15 PM |
Could you
Use a pair of bike sprockets connected with a short chain ?
907
| posted on 8/2/06 at 09:47 PM |
Hi Tim
You have u2u
(Looks a bit too posh for my garage mate)
Gary, Thanks all the same.
Pete, With a chain both shafts would rotate the same way.
I need one to go c/wise, one anti c/wise so they feed the sheet through, hence, two cogs.
All the web sites I've looked at only give the number of teeth, none give the diameter.
Anyone got a Myford lathe and can tell me the number of teeth a 45 or 50mm change wheel has?
Many thanks
Paul G
liam.mccaffrey
| posted on 9/2/06 at 12:15 AM |
i'll second hpc gears verry cheap compared to others too
you can specify bore and keyway also i think, may be wrong on this thiough
Build Blog
Build Photo Album
