chrisg
| posted on 18/2/06 at 11:58 AM |
Mini Clutch slave cylinder
Anyone got one of these surplus to requirements?
cheers
Chris
Syd Bridge
| posted on 18/2/06 at 12:20 PM |
Two types Chris, early and late(verto type, as fitted to early Metro's).
Early is about £10+ from Partco, late is twice that.
Syd.
[Edited on 18/2/06 by Syd Bridge]
chrisg
| posted on 18/2/06 at 12:42 PM |
Thanks Syd!
It's for the servo plan you had, which type would be the best one?
Chris
donut
| posted on 18/2/06 at 05:59 PM |
Chris, if you find out which one you need then drop my mate Dave an email min1dave@aol.com
| posted on 18/2/06 at 06:06 PM |
The verto one needs the pipework that goes with it or it doesn't work. It has a restrictor or something in it which increases the hydraulic
pressure from the master.
Syd Bridge
| posted on 18/2/06 at 06:25 PM |
Pete,
I think (well, I'm quite sure) you'll find the two slaves are swappable. Some Metro's had a 'Damper' in the system , but
it can be omitted in most cases.
We've run both types in the racing Mini's for seven years now, with no problems with either.
Some of the Metro slaves had bigger fittings in the tube end. I've got a box of 'em. 12mm if I remember. AND you can use 3/16 tube with
no probs, before anyone mentions it. We use Cu/Ni with aeroquip flexi's.
Syd.
Ferg
| posted on 18/2/06 at 07:28 PM |
My wife's MG Metro had that damper. It was a glorified restrictor that let the clutch out slowly even if you took your foot off quickly.
It's other purpose was to spring a leak on her way home from work, leaving her stranded......
| posted on 18/2/06 at 07:51 PM |
Sorry then Chris.
The verto one on mine wouldn't work without the restrictor, I tried it and had to put it back.
| posted on 18/2/06 at 08:54 PM |
When I fitted an MG lump in my pick up I left the damper off with no ill effects.
chrisg
| posted on 19/2/06 at 05:39 PM |
Thanks for the replies chaps, It's the earlier one I'm after, i'll try Donut's mate.
Chris
andyps
| posted on 20/2/06 at 01:40 PM |
Chris,
I think I have probably got one or two laying around, can't guarantee how good they are but were working when taken off.
chrisg
| posted on 20/2/06 at 03:33 PM |
I love you Andy!
Chris
andyps
| posted on 20/2/06 at 04:21 PM |
Now I'm worried
chrisg
| posted on 20/2/06 at 08:26 PM |
donut
| posted on 20/2/06 at 08:47 PM |
I love you Andy!
Steady on old bean!! I'm a married man don't you know!!
andyps
| posted on 21/2/06 at 02:00 PM |
I have got one Chris - will it wait until the next pub quiz?
chrisg
| posted on 21/2/06 at 03:31 PM |
That would be great Andy, It won't be expensive will it?, as you know my meanness is legendary!
Poor Chris
andyps
| posted on 21/2/06 at 05:15 PM |
I'll let you buy me a beer - I am sure you can manage that
[Edited on 21/2/06 by andyps]
chrisg
| posted on 23/2/06 at 04:35 PM |
Half?
Of tap water?
With two staws?
Chris
