Author: Subject: Someone with a lathe ...
RazMan
posted on 27/2/06 at 09:11 PM Reply With Quote
... to turn me a couple wishbone pivots.
I need some 1/2" x 240mm high tensile bar with 25mm of 1/2"UNF tapped each end. Preferably plated but hey - beggars can't be choosers!
Beer tokens waiting
[Edited on 27-2-06 by RazMan]
Raz
BKLOCO
posted on 27/2/06 at 09:51 PM Reply With Quote
I can do that for you Mike but need to source the material from somewhere.
What was the name of the Hydraulic people in Colchester?
RazMan
posted on 27/2/06 at 09:58 PM Reply With Quote
Brian you are an absolute star!
Anglia Hose & Hydraulic - 263 London Road near the garden centre.
Tel: 01206 212168
Raz
omega 24 v6
posted on 27/2/06 at 11:00 PM Reply With Quote
ERM if you tap 1/2 inch round bar with a 1/2 inch tap then surely you'll need the optional box of invisible air threads
Methinks there's a typo somewhere.
RazMan
posted on 27/2/06 at 11:04 PM Reply With Quote
Ahem - you are quite right of course
A die might be better in this instance
Raz
omega 24 v6
posted on 27/2/06 at 11:05 PM Reply With Quote
AH it all makes sense now
RazMan
posted on 27/2/06 at 11:24 PM Reply With Quote
Raz
BKLOCO
posted on 28/2/06 at 06:39 PM Reply With Quote
Mike the best I can find in 1/2 inch is some silver steel.
Not exactly high tensile. From memory its a high carbon steel with about 1.5% carbon, about .5% chromium and a touch of Manganese as well.
Generally used for shafts etc. in its un-hardened state but when hardened can be used for all sorts of things. Punches dies and cutting tools to name but a few.
It should be ok un hardened I think but perhaps some others with more application knowledge will advise.
RazMan
posted on 28/2/06 at 10:20 PM Reply With Quote
I remember from my school days that silver steel is tougher than mild but otherwise I'm a complete numpty on such matters so I would have to rely on the knowledge of others too.
Raz
flak monkey
posted on 28/2/06 at 10:31 PM Reply With Quote
Silver steel is:
About 1.2% carbon, 0.45% chromium, 0.3% manganese.
Its very brittle if hardened, but can be tempered, not an easy job to do accurately at home though.
As for the specific properties of it, do a search on google, i am sure it will turn up what you need.
Probably the best or easiest thing to do if you cant get any HT bar is get some oversized HT studding and turn it down and recut threads on it. Bit of a guff way around it, but if its the only way...
[Edited on 28/2/06 by flak monkey]
Sera
http://www.motosera.com
RazMan
posted on 28/2/06 at 10:45 PM Reply With Quote
Thats a novel idea there Flak. I've been searching for spec comparisons but have come up with zilch so far
Maybe stainless would be ok?
[Edited on 28-2-06 by RazMan]
Raz
flak monkey
posted on 28/2/06 at 10:49 PM Reply With Quote
If you wanted to try that idea you would need to go upto M16 studding to start with. As its got a core diameter of 13.5mm, and you need an OD of 12.7mm
Stainless - Been there several times. Its no where near the strength of HT bolts...sorry. Fatigues quite badly as well I think.
Sera
BKLOCO
posted on 28/2/06 at 10:55 PM Reply With Quote
We may just have some big cap heads laying about but not sure about the length. I don't really want to use silver steel it's evil stuff to machine. Leave it with me Mike.
By the way I got my hose end done £6.00 really nice people too.
RazMan
posted on 28/2/06 at 10:59 PM Reply With Quote
I didn't think that it would be such a pain to find the right material - or am I over speccing the stuff?
Bearing in mind these pins will be supporting each corner of my car (along with shocks & wishbones) can I get away with a lower spec?
Raz
RazMan
posted on 28/2/06 at 11:01 PM Reply With Quote
That's good news Brian - I found them really helpfull too and was really suprised when they made my adaptors while I waited. A refreshing change from some companies I could mention.
Raz
posted on 1/3/06 at 12:22 AM Reply With Quote
Are they 12.9? Most of the ones I've used have been.
BKLOCO
posted on 3/3/06 at 04:57 PM Reply With Quote
I,ve got your wishbone pivots Mike.
I'll bring them round in the morning.
How did the plastic bending go?
RazMan
posted on 3/3/06 at 06:26 PM Reply With Quote
Woohoo!
That's brilliant Brian! I'll be around all day.
I havent had a chance to look at the plastic bending yet - I've been bending ears at Aeon today about my front section. It really exists but it is still not finished and all I get is 'ready next week'. Trouble is it has been 'next week' since Xmas!
Got my doors to play with now anyway so it isn't all bad.
Raz
Mix
posted on 3/3/06 at 07:28 PM Reply With Quote
At the risk of upsetting people, here we go.
You seem to be concerned about the shear strength of the wishbone pivot. From memory the shear strength is generally asumed to be 60% of the tensile strength.
Before spending 'hard earned' it may be worth considering what this pivot, (a 12mm bar), is attachet to:
I'm guesing but how about:
A 3mm mild steel braket attached to a 1.2 / 1.5mm RHS box section.
Under these conditions which do you think the more likely to yield?
Mick
BKLOCO
posted on 3/3/06 at 07:48 PM Reply With Quote
Your'e not upsetting me Mick it's a very valid point.
Unfortunately the issue wasn't really the material spec as much as the fact that Mike couldn't find a supplier of 1/2" UNF bolts longer than 8" and he needed 81/2" to get the nut on with 2 full threads showing past the nylock to keep Mr SVA happy.
I agree than a lump of EN1a would probably be strong enough in this application (especially in double sheer) but it's not good practice.
Brian.
RazMan
posted on 3/3/06 at 10:58 PM Reply With Quote
.............. and I'm just happy to have my front end firmly supported on non-bendy bolts
Raz
