Author: Subject: In Line Electric Fuel Pump
rusty
posted on 9/3/06 at 08:34 AM Reply With Quote
Looking for an in line Bosch electric fuel pump as fitted to lots of differnt cars.
Engine will run but just needs the pump.
Please Help
omega 24 v6
posted on 9/3/06 at 12:44 PM Reply With Quote
Vauxhall carlton 2 litre's inj mate. Some are in tank but some are in line and are just what your looking for.
ChrisGamlin
posted on 9/3/06 at 02:06 PM Reply With Quote
It depends if you're running carbs or fuel injection........
rusty
posted on 9/3/06 at 02:22 PM Reply With Quote
I allready had a pump but it is now broken the engine ran for 30 seconds then the pump died
ChrisGamlin
posted on 9/3/06 at 02:28 PM Reply With Quote
......but are you running carbs or fuel injection? Without that info there's no point people recommending one or t'other
rusty
posted on 9/3/06 at 03:09 PM Reply With Quote
Oh right I see what you are getting at.
I have injection but I know what pump I want the reason the existing one blew was that it got some swarf in it from new tank but I have now fitted a pre pump filter.
The mount I have made under the back of the car is desgined to take a bosch in line pump like this one.
ned
posted on 9/3/06 at 03:12 PM Reply With Quote
as said some old vauxhalls use these - mk2 astra's, cavailers etc.
Ned.
beware, I've got yellow skin
rusty
posted on 9/3/06 at 03:19 PM Reply With Quote
Yes the faulty one is out of a Nova GTE.
No one got one kicking around then.
Dam swarf that will teach me.
omega 24 v6
posted on 9/3/06 at 07:03 PM Reply With Quote
I'll have a look you might be very lucky. It'll be the weekend though before I get out.
I have once before removed/stripped the crimped ends of one of these pumps and removed the poo that was blocking it. You could try this as you won't break it any more than you already have.
[Edited on 9/3/06 by omega 24 v6]
paulf
posted on 9/3/06 at 07:51 PM Reply With Quote
I found one under a Sierra last week , a bit hard to get at in the scrapyard but a good source .Its just behind the axle on a mount with a damper unit as well .
Paul
paulf
posted on 9/3/06 at 07:52 PM Reply With Quote
I am trying to work out how to mount my pump and filter but its a bit tight for space, have you any photos of how it fits?
Paul.
omega 24 v6
posted on 9/3/06 at 09:22 PM Reply With Quote
It sits inside what can only be described as a huge rubber grommet, made out of neoprene type material with a saddle across it to secure.(just read this and hope it makes sense)
So an inner tube cut into 2inch wide strips and wrapped round a couple of times would probably do the job nicely.
trextr7monkey
posted on 9/3/06 at 10:09 PM Reply With Quote
Hi, sorry no pump but if its from a vauxhall have a trawl through this site and hopefully you will getfixed up sharpish
http://www.cavweb-forums.co.uk/forumdisplay.php?s=633c74db1a2abd219c01b9880bdbca71&daysprune=&f=83
rusty
posted on 10/3/06 at 07:59 AM Reply With Quote
Pump and outlet side filter mounted here in two lengths of alloy tube.
paulf
posted on 10/3/06 at 09:23 PM Reply With Quote
I have found an ignition coil bracket is a good fit with a layer of bike inner tube between it and the pump , just need to sort out a layout to accomadate pump , inlet filter and swirl pot plus low pressure pump.I intend to fit a boot floor so am restricted to the lower half of the rear bulkhead or on the lower chassis rails infront of the axle.
Paul.
